Can you clean a lambda sensor
Old May 1, 2014 | 08:53 PM
Mk4 Rick's Avatar
Mk4 Rick
Default Can you clean a lambda sensor
To my knowledge my lambda sensor has done 143 thou can you clean them up to help restore any lost power
Old May 1, 2014 | 10:47 PM
GVK.'s Avatar
GVK.
Lambda sensors info is only used in idle and cruise (PART THROTTLE) situations on something as old as that. Known as 'closed loop' operation where the feedback from the various sensors is used and the PCM tries to keep the AFR at Lambda 1 (14.7:1 AFR)
On full throttle the fuel system is in 'open loop' and AFRs will be lower (richer) for full power/torque and component protection.
If your car passes the MOT emission test and has no error codes relative to Lambda sensor, it should be working fine.
Old May 2, 2014 | 07:31 AM
Mk4 Rick's Avatar
Mk4 Rick
Thanks for the help.Ive got no errors its fine just thought with age related wear and with where the lambda sits it picks up shite eventualy resulting in a blocked up lambda
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
stevecfrst1
Sep 30, 2015 05:18 AM
