Electrical discharge
Old Apr 10, 2014 | 06:18 PM
gingeRS's Avatar
gingeRS
Exclamation Electrical discharge
The radio on my focus is rubbish (pioneer aftermarket)
It only picks up strong signals and gets interferes with them (bbc radio etc)
I have noticed if you tune in a station and it's fuzzy, if you switch the engine off it stays fuzzy for 10 secs then signal gets good. I assume this is after the alternator finishes charging. The alternator was new very recently, but pr.oblem has been there a while, any sugggestions where to start looking for a fault/fix?
Old Apr 10, 2014 | 06:19 PM
STeve's Avatar
Super Moderator
try a inline signal booster
Old Apr 10, 2014 | 06:37 PM
RichieST's Avatar
RichieST
Check the aerial is earthed properly behind the interior light. Is it plugged in to the back of the headunit properly? They do pop off pretty easily.
Old Apr 10, 2014 | 08:06 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I hate car stereos mine is doing my head in! I've not got the best of bits but when listening to the radio it sound tiny and shit but listening to music off my phone plugged into it it's like a totally different system?
Old Apr 10, 2014 | 09:20 PM
martysmartie's Avatar
martysmartie
Your car has an amplifier fitted for the antenna, so first make sure this is functional...
OP, it sounds like you have EMI (Electro Magnetic Interference) this will change in proportion to engine speed. The first things to check are is the ignition system and alternator. To prevent this they are 'supressed' basically there are capacitors which are in turn grounded. The ignition leads should also be supressed.
Martin
Old Apr 10, 2014 | 09:35 PM
ajamesc's Avatar
ajamesc
I don't have a signal problem that's perfect just sounds so tinny and quiet no bass but once playing music from the phone sounds 10 times better far more sound quality
Old Apr 11, 2014 | 03:16 PM
martysmartie
How do you know that? If that is the case then the head unit is probably at fault, issues like this though are usually down to poor signal IME.
Martin
Old Apr 11, 2014 | 03:54 PM
gingeRS's Avatar
gingeRS
Exclamation
Martin
I doesn't change in proportion to speed, it's as simple as the radio is great with the engine off but turns to dogs hit when the engine is running. Where do I is start looking for these suppressors on a 2003 focus???
Old Apr 11, 2014 | 04:24 PM
ajamesc's Avatar
ajamesc
Martin
Head unit is brand new signal must be good as I can pick kiss 100 that normally you can't
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
stevecfrst1
Sep 30, 2015 05:18 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
