Kawasaki Carb conversion
Hi Guys
I have a Tiger Supercat fitted with a 2ltr Pinto engine (205 block). The engine is standard with the exception of the camshaft, which is a Burton high torque camshaft BF134. The camshaft description is as below:-
Power band 1000-6500rpm. Valve lift .460". Duration 266deg. Timing figures 23/63/63/23. Inlet timing 110deg ATDC. Clearances .008"/.010".
I have replaced my twin Weber 45s for a motorbike set up using Kawasaki 36mm ZX6R carbs (a recognised conversion).
I anyone out there has a similar conversion I would love to know the MAIN JET size you use, plus any other help would be welcomed.
Geoff Hull
Geoff Hull
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
