thread sizes
Old Mar 26, 2005 | 01:35 PM
Paddy rst's Avatar
Paddy rst
Default thread sizes
anybody know what the thread sizes are of the rs turbo air-charge, and water sensors??. And the sizes of the cosworth air-charge and water sensors???
Is there an adaptor you can buy so the cosworth charge air and water sensors can fit in the same positon as where the sensors are fitted as standard on a rs turbo??
cheers Paddy...
Old Mar 26, 2005 | 01:55 PM
richm's Avatar
richm
Cosworth Temperature sensors, threads:
ECT – M12x1.5
IAT – M14x1.5
sorry, not certain of RST, but from memory IIRC they are 3/8" BSP
Old Mar 26, 2005 | 04:34 PM
Red16's Avatar
Red16
Default Re: thread sizes
cheers Paddy...
go to Pirtek (hydraulic equipment specialist) on the Team Valley mate, they will sort you out with whatever pipes/fittings/adaptors you need
Pirtek
Unit 269a
Queensway South
Team Valley Trading Estate
Gateshead
Tyne & Wear
NE11 0SD
Tel: 0191-487 9996
Fax: 0191-487 1119
Old Mar 26, 2005 | 04:52 PM
**Claire**'s Avatar
**Claire**
Hey there bruv
Nice to see u on here, the durham site is well quiet at the min..... not very often i see u posting on here.
Says her with only 30 posts
Old Mar 26, 2005 | 04:56 PM
leesrs240's Avatar
leesrs240
Paddy im sure you could just take scotts as he dont need them
Paddy give fen a ring he may have a full set
Old Mar 26, 2005 | 05:36 PM
richm's Avatar
richm
take a 3/8" - 1/4" BSP reducer bush, bore out the centre to tapping size and retap the metric thread inside.
ECT – M12x1.5 tapping drill size 10.5mm
IAT – M14x1.5 tapping drill size 12.5mm
you will find that the M14 thread leaves a VERY thin wall section inside the 3/8" reducer, and you will need to bore and tap it central to ensure the tap doesn't break out. The resulting adaptor will be quite fragile until everything is fitted - loctite the adaptor into the manifold or x-over pipe or wherever and pinch it up carefully.
Old Mar 27, 2005 | 01:27 PM
Paddy rst's Avatar
Paddy rst
cheers for the info peeps ...sis just keep posting
boeb
Jan 9, 2020 05:11 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
