Koni adjustables
22-03-2014, 07:08 AM
The annoying ginger guy
Koni adjustables
I fitted some rear koni adjustable shocks on my saff but can't find where to adjust them?
Is the the 2 holes on top that you use to turn them as I bought them used
22-03-2014, 07:11 AM
Pick-up P100 Power!
Quote:
Originally Posted by
gingerturbo
On the top mate off the strut. I'll pop out and take a pic for you if you want
22-03-2014, 07:14 AM
That's for the front ones ain't it, the rears have only got what looks like a retainer that a special 2 pin tool turns
22-03-2014, 07:15 AM
DixieTheKid
Cheers I could be missing something, its only I want to stiffen it as much as I can as the wheels are just about tucked inside the arch
22-03-2014, 07:34 AM
Where the shinny part of the shocker goes into the shocker body there is s little button. I think you will have to remove one of the shocker bolts then twist the body of the shocker round till you feel it click.
Im sure on mine therebare 3 settings.
What I wanna know myself is which setting is soft ie do you turn the shocker left for soft or right for soft.
22-03-2014, 07:39 AM
Just found this pic on google.
22-03-2014, 07:46 AM
Pick-up P100 Power!
Right makes it harder from memory
Mmm that's weird mine ain't got a button? But they state adjustable on the shock?
22-03-2014, 07:52 AM
Pick-up P100 Power!
gingerturbo
They don't have a button. Close the damper a screw it clockwise me make it stiffer and anti clockwise to soften
22-03-2014, 07:54 AM
22-03-2014, 08:00 AM
Pick-up P100 Power!
Mine have buttons.
Mine don't
22-03-2014, 08:36 AM
Ah ok will it stop turning once you've reached max?
22-03-2014, 02:47 PM
Yeh the ones with the buttom stop at full adjustment.
22-03-2014, 02:54 PM
22-03-2014, 04:16 PM
Did you find a button on your shocker then or not.
22-03-2014, 05:12 PM
Nah it the same type as dixies, push shocks in and twist clockwise
22-03-2014, 07:34 PM
Shark conversions
my rears you have to unbolt bottom of shock and hold the little botton on the collar and turn it but they are not for sofening or hardening its for when the shock wears and gets softer you can stiffen it up a click to get more life out of the shock.
23-03-2014, 12:09 AM
I never knew that Sharky.
yatta
21-05-2016 10:31 PM
01-11-2015 06:53 PM
Fezman1
02-10-2015 01:22 PM
IainRS1700T
25-09-2015 06:44 AM
truffleshuffle
10-09-2015 09:35 PM
