Towing my mk3 escort on a trailer with my mondeo st 220?
Basicly I want to start taking my Rs turbo and my st220 to some shows instead of just one.
Will my mondeo be ok doing this?
It's lowered 40mm and running on 20" rims, is there any way I can tow without changing any thing? Cheers
That's usually the case providing you don't exceed the maximum towing weight of that vehicle.
The ST220 isn't plated at all for towing therefore you cannot tow at all.
Look in your owners handbook, it says something along the lines of... It is not permitted to fit a towbar to an st220.
I dont know why, it just isn't.
I'm not 100% but i think it is due to rear structural changes for the exhausts, so the correct mounting points for the tow bar are no longer there.
Received 1,044 Likes
So what if you welding strong sections of chassis leg to the back of the mondeo then took it to a vehicle testing station and got someone to check it over. Would that not work??
The mk1 Fabia vRS can't legally tow a trailer even though it's the exact same shell as the normal cars (which are type approved).
There's a guy local to me with an identical vRS to mine's and he has a two bar fitted which he uses regularly
So basicly By the sounds of it, it's a load of bull? I'm going to have a look round and see what bars will bolt on.
Cheers guys
Cheers guys
I know on the Fabia it certainly does fit, it's almost as if Skoda decided that no-one would want to tow with a vRS so didn't have it type approved. Not sure if it can be retrospectively applied.
Don't know if there have been changes made to the Mondeo chassis that would prevent you from physically fitting one but I know I wouldn't let it stop me towing with it. Smart idea or not I'd be tempted.
States the the handbook that the ST220 cannot tow!
Its same for Audi RS4's also, the more high performance of the range seems to be affected by it for whatever the reason.
Resident Wrestling Legend
The reason it was hemoglobined for riding us that the rear bumper under tray needs to be cut
Everything else is exactly the same as any other Mondeo as far as fixing points go in the chassis rails so all this talk about it being different is bollocks
There's even a slot to mount the offside exhaust hanger in the chassis rail
I've got an st kit on my estate and other than fitting a sponge between the bumper and the tow bar, everything gets just fine and dandy
So based on the "technicality" that they didn't doesn't mean to say that you can't, ford didn't bother so you can't, and don't buy into the dmf failing talk either
you sure they type approved the sttdci ?
the petrol one wasn't for the reason that they didn't want to chop about the rear end or sell specific kits to mount the bar an inch further out but that was back in 2002 when they first came out, the sttdci came out later so if they did for that then what did they change?
As far as I was aware the ST220 was Fords flagship model so Ford didnt want the aesthetics of a towbar taking away from its sporting image, whereas all other models in the lineup were homogolated for towing including the ST TDCI.
This would tally with other stories on here such as VRS and RS4s not being homogolated but their less sporty models being type approved
