Anyone use the car moisture absorbing bags?
#41
I use it nearly all the time when it's raining or damp outside, just keep the fan setting on a low speed towards the windscreen with A/C switched on, no fogging up issues anywhere in the car. Don't notice any change in MPG or driveability on with it either.
#44
#46
I tried it on my Astra & it made it worse if anything leaving a milky sort of residue on all the windows I put it on. Thinking I must of done something wrong I cleaned it all off & started from scratch with the same result.
After asking my mate who bought a tub at the same time as me how he got on with it he had exactly the same results so over all my recommendation is don't bother
#48
I think the fact I'm so light on the throttle doesn't help matters.
That said I don't hang about either! I just try to be gentle and smooth.
But removing the seats is just silly.
A/C gets used when it needs to be used! During the summer it's on constantly.
During the winter I make sure I use it for 30mins a week too just to keep it working, but I use it for demisting if I have too!
The dehumidifiers work perfectly well.
#49
When I pull off with A/C on it seems to bog down more, I have to give it quite a bit more throttle. It's been the same with all my cars that have had A/C.
I took my spare wheel out and bought a genuine Ford compressor with the built in tyreweld to save a little weight.
On another note, do you have the finis for the door module you fitted to your mondingo to activate the power mirrors with locking? I've seen the part number on another thread of yours but if you had the finis that would be fan-dabby-dozey.
Cheers!
#52
Resident Wrestling Legend
anyway, my bags turned up yesterday and so i stuck them in the car
this morning, no condensation inside
bought 2 of these
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEAFB:IT
one on the dash, one on the rear seats, job jobbed me thinks
#54
its not the compressor, it's the ecu which disengages it at full throttle, sierras with ac from 25 years ago had these feature so i'm not sure why anything newer would remove that?
bought 2 of these
bought 2 of these
#61
over the past winter it's had icicles on the inside of the windscreen, but all the other windows were fine
#62
Happily retired
Mine arrived yesterday as well. Will know in the morning if it improves things sounds hopefull.
#64
Made in Scotland
my car tends to sit for many months at a time in some cases (longest was 8 months) so i'd rather have more belt and braces than the potential for it to fill up and then not have anything else to suck up the mostiure
One for FRS, one for ST200, one for housemate's Golf and one spare.
Cheers,
Grant
#65
My mate has an Astra and it's always like a sauna for steam it's so shit. My mk2 focus and my girlfriends mk6 Fiest have no steamy window problems at all. Even with 4 people.
I usually have the heater on setting 1 all the time on the feet/windscreen setting and blank off the two inner vents and open the side dash vents aimed at front door windows. Temperature just depends on how comfortable I or passengers are with the temperature
#66
Will be getting a couple myself. But, for the time being, I noticed that the 1kg bags of silica that we get in the shipping containers at work are more or less the same stuff. And what do you know, after a couple of hrs in the boiler room at work drying they have done the job. With the tight security we have, I had to pay 50p to take 4 bags. Not bad eh. The real deal might be better again regarding longevity, so I will try them too.
#67
Testing the future
#71
and again this morning, inside is dry as an AA meeting but the outside windscreen has a film of water on it
they dry out themselves from what i gather, they capture the moisture in the air when it exceeds one point and then release it back when it's too dry
steerfromdarear
28
29-01-2016 06:14 PM
