Celica gone wrong again!!!!
Old Nov 25, 2013 | 05:29 PM
RSBryden's Avatar
RSBryden
10 Year Member
Default Celica gone wrong again!!!!
Coming back from work in it, was giving it sum stick in 4th, then it coughed a bit n loss of turbo . Feels like te turbo has fell out of car. No boost no wind no dump valve, n engine sounds bit rough when revving it , boost pipes seem fine n she idles on n drives ok but without turbo power, no smoke or no lights on in dash
Old Nov 25, 2013 | 07:03 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Actuator give up, vac pipe, waste gate stuck, hole in intercooler?
Old Nov 25, 2013 | 07:05 PM
saph4be's Avatar
saph4be
Boost pipe popped off?
Old Nov 25, 2013 | 08:05 PM
RSBryden's Avatar
RSBryden
10 Year Member
It's got top mount cooler,
No boost pipes or any pipes popped off or split,
Actuater I'm unsure off,
After running for a while it developed a slight tap noise coming from the cam belt side, but that stopped after I revved her,
Exhaust fumes smell funny, not like burn feul, strange smell,
The incar boost gauge shows she builds up half way between - and + on the standard gauge!
Old Nov 25, 2013 | 08:06 PM
RSBryden's Avatar
RSBryden
10 Year Member
Dunno what's going on! I think I'm gona half to put her into a specialist n get raped for ŁŁŁ!
Old Nov 25, 2013 | 08:07 PM
bigchez's Avatar
bigchez
i had similar when my actuator rod snapped on the cossie, might be worth checking
Old Nov 25, 2013 | 08:08 PM
gingerturbo
I know someone else will say it aswell but if you would of tool it to a specialist you may not be in this situation now
Old Nov 25, 2013 | 08:12 PM
RSBryden's Avatar
RSBryden
10 Year Member
Ginger turbo, the person that did the work i required managed to put right wot went wrong, she was running right last night and today but it 4th sh lost power
U sound like my misses ( told you so) lol :s
Old Nov 25, 2013 | 08:14 PM
RSBryden's Avatar
RSBryden
10 Year Member
Big chez ill have a look tomorow when it's light, but right to get to actuater, gotA remove turbo cover n top mont cooler to get behind!
The car drives spot on still just no turbo, it's as if someone cut the turbo off! Just nothing there
Old Nov 25, 2013 | 08:25 PM
bigchez's Avatar
bigchez
Hmmm, sure I saw a thread the other week where these were described as a ball ache to work on!!
It has to be either a huge boost leak with a split pipe or intercooler (and if so you may well see a massive cloud of fuel smoke out of the back) or something to do with the actuator or if you're really unlucky turbo shaft might have snapped.
Old Nov 25, 2013 | 08:26 PM
gingerturbo
Lol I get it all the time, the rattling may of bin the wastegate flaps flapping about and there now wedged
Old Nov 25, 2013 | 08:28 PM
gingerturbo
Was the car used a lot since you bought it as if not then you may well have snapped the turbine shaft as the exhaust side might have seized up
Old Nov 25, 2013 | 08:34 PM
RSBryden's Avatar
RSBryden
10 Year Member
The car hasn't been used in 5 years
I give her what she needed, new feul. Rad. Oil. Service. Belts thn took her to the garage n it some octane boost,
Did thrash the arsenal off it to the redline in 1st, 2nd,3rd,4th n then it went ......
Defo turbo related then guys?
Old Nov 25, 2013 | 08:35 PM
gingerturbo
I'd say so
RSBryden's Avatar
RSBryden
10 Year Member
The car didnt smoke wen it went, not did it smoke after warmed up, a little smokey now but my pal recons it's condensation smoke??
Old Nov 25, 2013 | 08:37 PM
RSBryden's Avatar
RSBryden
10 Year Member
There is oil coming out of my air filter , but this filter had an elbow were the breather pipes join to it also other than just the turbo.
Old Nov 25, 2013 | 09:03 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Sounds to me like the actuator rod has come off.
The fact that it runs and drives ok apart from the lack of boost doesn't suggest there is a leak in the intake system as I'm pretty sure on these they have an air flow meter so probably wouldn't run right if there was.
Old Nov 26, 2013 | 11:51 AM
stevieturbo's Avatar
stevieturbo
C**t
Based on the very vague description, it could be anything from a boost pipe, actuator, blown turbo right through to blown engine.
And oil in the air filter is rarely a good sign.
Old Nov 26, 2013 | 12:12 PM
RSBryden's Avatar
RSBryden
10 Year Member
Engine runs spot on,
No leaks or split pipes,
Pressure tested the system and all pipes are good,
Narrowed it down to actuater or exhaust turbine,
Gone remove mani and turbo this evening and have a troubleshoot!
Old Nov 26, 2013 | 12:16 PM
stevieturbo
C**t
Turbos on them arent renowned for their reliability......and whoever designed the brackets to bolt the turbo to the engine....needs sliced into small pieces bit by bit.
Old Nov 26, 2013 | 12:19 PM
RSBryden's Avatar
RSBryden
10 Year Member
That's abit aggressive lol, do you own a gt4?
If turbo knackered ill be uprating it to something alot bigger, dunno what tho! Needto have a read up !
Bloody tight in there to get to things tho , gotta remove all casings before u can even see the turbo :s
Old Nov 26, 2013 | 12:21 PM
RS Grant's Avatar
RS Grant
Made in Scotland
You'll be best running a GT28.. and get it mapped properly to keep the car below 1.2bar of boost; since the standard internals, particularly the rings, don't like anything too boosty.
Cheers,
Grant
Old Nov 26, 2013 | 12:25 PM
RSBryden's Avatar
RSBryden
10 Year Member
How much power could be possible to achieve with the gt28 front mount n mani n exhaust with cams?
Old Nov 26, 2013 | 02:21 PM
stevieturbo
C**t
Owning one and working on one is very different. Owning is easy, and I would never own one. If the turbo and cat have never been touched, their removal is a complete nightmare. So hope someone has been in there before and left a lot of bolts out. And don't think the factory ecu can easily be remapped ?
Old Nov 26, 2013 | 04:02 PM
scoooby slayer's Avatar
scoooby slayer
I have had a Renault laguna do this.
my cousins car, the turbo was shot the shaft had twisted in the housings and impeller catching comp housing due to wear and simply wouldn't turn anymore so I fitted a new shaft and bearings/seals for him.
im not saying its the cause but it sure is a possibility.
Old Nov 26, 2013 | 04:05 PM
stevieturbo
C**t
The ST205's use some silly ceramic turbine'd turbo. Great in theory, but they are very fragile.
Old Nov 26, 2013 | 06:33 PM
RSBryden's Avatar
RSBryden
10 Year Member
Just had the top mount off, 3/4 of hear sheilds around turbo, fck me the japs must have small hands,
It's so tight, no room for a fag paper,
Couldn't get to the actuater rod, but felt it n the slip pin is still in and the rod a isn't snapped!
Managed to get some long nose on the rod and I can just get it pulled out enough to here the gate open n close,,,,,,,
Slight play left to right were the rod goes into actuater is this normal?
No play in turbo shaft up or down( in or out !
I'm clueless, does anyone no any specialises to take her too around Essex area???
Cossie Sean????
Old Nov 26, 2013 | 06:39 PM
gingerturbo
Vac problem?
Old Nov 26, 2013 | 07:04 PM
RSBryden's Avatar
RSBryden
10 Year Member
I dunno what u mean bud
Old Nov 26, 2013 | 08:03 PM
RS Grant's Avatar
RS Grant
Made in Scotland
No need for a front mount, standard charge cooler is fine up to c400bhp... fitting a GT28 with an exhaust, flexi, downpipe, intake, pump, injectors and an aftermarket ECU with pro mapping should see you with a genuine 350bhp and an attractive graph.
That was certainly true a couple years or so ago when I was on the owners club, doubt it will have changed but you never know I guess.
Cheers,
Grant
Old Nov 26, 2013 | 08:11 PM
RSBryden's Avatar
RSBryden
10 Year Member
350 sounds interesting!
Gona get her sorted , looking for a specialist to sort her out! I'm out of ideas now !
Bloody nightmare them engines to work on.....
Old Nov 27, 2013 | 06:35 PM
RSBryden's Avatar
RSBryden
10 Year Member
Ok after self diagnosis and reading up online I have found that the engine is displaying error code 54-
Error code 54- chargecooler level sensor.
If this sensor is broke the engine goes Into limp mode and retards the timing and cuts off the boost.
( hopefully it's just a case of replacing this)
As I turn the key u can hear under the cam cover a noise indicating the timin is being offset!
(Strange)
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
DavidK
Sep 27, 2015 02:55 PM
Daniel Howard
17
Sep 26, 2015 12:39 AM
Alloy wheels and ICE for sale
Sep 19, 2015 07:50 PM
