Timing out??
Old Nov 23, 2013 | 04:38 PM
RSBryden's Avatar
RSBryden
10 Year Member
Default Timing out??
Automatic tensioner unit snapped , had it replaced n now the car seems too have no guts in it, it is a little jumpy on throttle, is it possible the cam belt has jumped a tooth causing her to run like this?
Old Nov 23, 2013 | 05:01 PM
GVK.'s Avatar
GVK.
Does this follow on from your thread asking about a cam belt swap on a Celica GT4?
Old Nov 23, 2013 | 05:02 PM
bigjohn0's Avatar
bigjohn0
What car is it ? Did you not check the timing again before you started it ?
Old Nov 23, 2013 | 05:06 PM
RSBryden's Avatar
RSBryden
10 Year Member
Yeh buddy it follows, got the came belt done n was good all running sweet, drive it home n then I herd rattling, so I towed it back to garage n he said the tensioner had gone, got it replaced , he just finished it in the dark lol took it up road n here I am lol, gutless, he is gona look at it in the day tomorow,
(Celica gt4) big John
Old Nov 23, 2013 | 05:11 PM
RSBryden's Avatar
RSBryden
10 Year Member
His excuse was the tensioner must off pulled the belt round n knock it out as it was slack by an inch!
He said the top 2 looked inline, but as it wa dark he didn't 100% check as they was lined prior to the tensioner going!
Poxy car getting on my tits
Old Nov 23, 2013 | 05:17 PM
bigjohn0's Avatar
bigjohn0
Oh that's not good mate. Lets just hope it didn't rattle the valves when the tensioner went otherwise someone is in trouble. Not having a dig but whenever i do timing belts (and that's alot ) i always change it as a kit to rule out this problem.
Old Nov 23, 2013 | 05:27 PM
RSBryden's Avatar
RSBryden
10 Year Member
Engine is very quite and idles lovely just doesn't feel 100% on throttle bit jumpy n not guts.
What would ur profession opionion be pal? Would u say the timing is out?
Old Nov 23, 2013 | 05:33 PM
GVK.'s Avatar
GVK.
Did it go right before you had the belt done? - YES
Does it go right since you had the belt done? - NO
I'm no Einstein but I think I can see the problem.
Old Nov 23, 2013 | 05:34 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Did they change the tensioner aswell as the belt or just the belt
Old Nov 23, 2013 | 05:37 PM
bigjohn0's Avatar
bigjohn0
I would say the timing is out but once you strip it again make sure 100% its right and before you even start it turn the engine by hand at least a full cycle then line everything back up to make sure its still 100% right. If it all lines up then give that a run up the road to see if its ok
Old Nov 23, 2013 | 05:43 PM
RSBryden's Avatar
RSBryden
10 Year Member
The belt was done before the tension was changed,
Hopefully it gets sorted tomorow' ill keep you updated , once again thankyou for your help guys !
Old Nov 23, 2013 | 06:12 PM
saph4be's Avatar
saph4be
Of it's running ok on idle maybe just a tooth out? Sounds poorly fitted.
Old Nov 23, 2013 | 06:43 PM
jamie's's Avatar
jamie's
to be perfectly honest its very poor workmanship if he's changed the tensioner because its collapsed and never bothered to check the timing because "they was lined up prior to the tensioner going", yeah the belt was also tight before it went as well
if its idling ok and running on 4 its prob not bent any valves, but just jumped a tooth
but bad work either way, i wouldn't realy recommend getting any more work done there
Old Nov 23, 2013 | 07:00 PM
GVK.'s Avatar
GVK.
Waiting for 'cossie sean' to post 'I told you so'
Old Nov 23, 2013 | 07:03 PM
jamie's's Avatar
jamie's
thats exactly what i thought when i 1st read it
Old Nov 23, 2013 | 07:23 PM
RSBryden's Avatar
RSBryden
10 Year Member
It's a constant head ache mate, took the day off work to drive 78 miles to pic up a new rad n automatic tensioner unit just so she would be running for me to drive, n now u can imagine the stress I have ATM,
The mechanic is getting it srted tomorow if he doesn't he will get a slap and ill take his fez rs off him he nos this.
Old Nov 23, 2013 | 07:38 PM
gingerturbo
Oh dear oh dear proper head ache, good luck with getting it sorted
Old Nov 23, 2013 | 08:10 PM
Mk4 Rick's Avatar
Mk4 Rick
Old Nov 24, 2013 | 03:03 PM
LHD220Turbo's Avatar
LHD220Turbo
is it fixed?
Old Nov 24, 2013 | 05:06 PM
RSBryden's Avatar
RSBryden
10 Year Member
Just been out in her for he last 2 hours n dam she is a weapon
I'm well pleased she finally fixed!
Result was 2 teeth out by timing , lucky it isn't done any damage to the engine,
Slight bit of vibration every now an again from rear diff hanger as the rubbers r a little worn .
Could do with a nice set up but ill get that done after new mani , front mount n exhaust arrives
Old Nov 24, 2013 | 05:20 PM
jamie's's Avatar
jamie's
good result, got lucky there, that could have ended a lot worse
Old Nov 24, 2013 | 05:27 PM
RSBryden's Avatar
RSBryden
10 Year Member
Yeh defo pleased mate been screwing at work all day hoping he sorted it, we got there in the end
Old Nov 26, 2013 | 05:04 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Whats the point in replying Gary,
try to help and they werent interested so fuck em.
Sean
Old Nov 26, 2013 | 06:36 PM
RSBryden's Avatar
RSBryden
10 Year Member
Don't be like that bud :s. Sean do you no anyone ho speacialize in gt4,
Engine is sorted n timing is all good!
No boost or nothing mate
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
