Different RON fuels
Hi all
I have always put shell vmax in my frs mk1. Now I noticed in the handbook it says to use 97ron fuels I guess as a minimum. Question is if I needed to use 97 on the odd occasion will it confuse the ecu and make it run bad? My car is bog standard so wasn't sure. I don't want to ever run the risk of being cut short
Yes, it is for high performance cars, if you run it on 95 it can damage the engine!
You can put it in a 'normal' car without an issue, although you won't get any gains from it, but you can't go the other way on car that is mapped for it.
Martin
Martin
The Octane rating or octane number is a standard measure of the performance of a motor or aviation fuel. The higher the octane number, the more compression the fuel can withstand before detonating. In broad terms, fuels with a higher octane rating are used in high-compression engines that generally have higher performance. Remember the air is already compressed by the turbo in forced induction engines. so there is a multiplier effect!
This means the higher the number the more the fuel can resist "pinking" (pre-ignition) and this very quickly destroys engines!
