Yb engine torque settings
Old Oct 1, 2013 | 06:55 PM
waynefrst235's Avatar
waynefrst235
Default Yb engine torque settings
Does anyone have a list of torque settings for a Yb?
It's a 2wd engine, cometic head gasket, standard head bolts if that makes any difference
Old Oct 1, 2013 | 10:33 PM
LHD220Turbo's Avatar
LHD220Turbo
30, 60, 90 lbft & torque the studs to 60lbft
Make sure you use shit loads of oil on the nuts, once all finished, leave it a few hours and re-check the 90 lbft torque setting
Old Oct 1, 2013 | 10:36 PM
LHD220Turbo
also, make sure you clean out the bolt holes, you dont want any debris or fluid in there at all
Old Oct 2, 2013 | 03:56 PM
waynefrst235
What studs and nuts do you mean??
It's standard head bolts I'm using
Old Oct 2, 2013 | 04:20 PM
LHD220Turbo
sorry, my mistake, i thought i read you were using studs. Either way "i think" the settings are the same
are you using genuine head bolts? not the cheap copies?
Old Oct 2, 2013 | 04:40 PM
rog's Avatar
rog
I'd call a cossie engine builder if you want a quick answer. I have the details but their at home and that's not much use when I'm sitting in Bucharest.... I googled it and got different number to what is quoted above
Old Oct 3, 2013 | 03:51 PM
LHD220Turbo
probably the best answer, its been years since i had a cossie so i am probably wrong
i just used the search thing on here and saw 2 different answers.
hopefully someone will provide the correct answer
Old Oct 7, 2013 | 07:46 PM
waynefrst235
I got a mate to check Autodata for them in the end. For future reference they are:
1: 20-25Nm
2: 45-50Nm
3: 180 degrees
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
Aug 30, 2015 08:07 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
