View Poll Results: When you fit big brakes do you -
Turn OFF the abs
27.27%
Leave ABS on
63.64%
Depends on the conditions
9.09%
Voters: 22. You may not vote on this poll
Big Brakes and ABS?????
Old 22-03-2005, 11:33 PM
  #41
Fastmaul
K155MYRS
Fastmaul's Avatar
I sometimes experience the pedal pulse, when I first turn on the car and the first drive it usually does that. My lights come on, but some time it pulses with out the lights being on.
Old 23-03-2005, 10:37 AM
  #42
Dan@Rapid-Ford
Dan@Rapid-Ford's Avatar
Took the car out last night with ABS on and done 120miles and the pedal definately felt better with it off
I dunno if its knowing if I wanna stop its gonna run on pulsing away
but just because the light doesn't come on, doesn't mean that abs is working properly (the bulb could be blown, or the car has sensor issues that cause this bloody annoying pedal pulse at low speed that a few of us are talking about).
but when I unplug it the ABS the light comes on when I plug it in the light goes off if the pulsing is a fault and its not showing I'm thinking its an issue with big brakes with standard ABS.
cheers for all the replies people.
Daniel
Old 23-03-2005, 10:44 AM
  #43
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Dan,
Must be a problem with your car, as mine is mint on the braking front with the ABS on, and you can't get much bigger than 378mm discs with the WRC CP6235 6-pot calliper....
Old 23-03-2005, 10:46 AM
  #44
RichardPON
RichardPON's Avatar
Originally Posted by Eagle
the higher clamping and biting forces of pads and calipers seriously thro them into a state of oh hell what do i do ....
So, is that the official technical explanation then?
Old 23-03-2005, 10:48 AM
  #45
Dan@Rapid-Ford
I'm thinking it must be the way I drive
Old 23-03-2005, 10:49 AM
  #46
Dan@Rapid-Ford
and how come your brakes are so big and you still hit that cone?? (sorry)
Old 23-03-2005, 10:59 AM
  #47
Mike Rainbird
Caraholic
Dan,
Because I was looking behind me and not in front of me .
Old 23-03-2005, 11:12 AM
  #48
foreigneRS
Testing the future
foreigneRS's Avatar
it's nothing to do with the bigger brakes dan. it does it on mine with std brakes, and sometimes on my other sierra 2.9 4x4. it's a minor fault, probably front sensors / sensor rings
Old 24-03-2005, 08:58 AM
  #49
foreigneRS
Testing the future
foreigneRS's Avatar
replaced the front sensors on mine last night, and the pulsing at low speed has stopped. everything mint now.
muzzman1
30-09-2015 08:59 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: Big Brakes and ABS?????
