escort efi
ignition management to run coilpack set up with external trigger wheel
different fuel lines and fuel pump and fuel reg
carb cam
and many other bits........
if you are serious about it, fit a carb head, carb dizzy, and facet fuel pump and filterking fuel reg, with return blocked up
thanks for that m8 , think I will give that one a miss - sounds like to much work for me . I was after more power , do u think I would be better zetec as apparently I can still use efi loom etc .
Dr. Ickxs
15-09-2015 10:15 PM
