Gotech mfi pro?
Old Aug 17, 2013 | 08:53 AM
rsmark86's Avatar
rsmark86
Default Gotech mfi pro?
Has anyone got a mapp to get my car running to give it a once over before taking it for mapping
Me and dubs44 are wiring up and doing the finishing touches today
Quick spec, 2.1 with vxr injectors, cos 4x4 t3, gotech mfi pro, grs cooler, dd valve springs, c20let pistons, stage2 rad, SO inlet
Any help would be great, and has anyone got a computer cable and software disc they want to sell? Or lend me
It's got a 1600cvh mapp on it but didn't want to take any chances?
Old Aug 17, 2013 | 05:35 PM
rsmark86's Avatar
rsmark86
Anyone?
P.s don't buy relays from halfords, brought 2 today and both don't work
Old Aug 22, 2013 | 06:05 PM
rsmark86's Avatar
rsmark86
Anyone?
Help.........
Old Aug 22, 2013 | 06:37 PM
stuartrsturbo's Avatar
stuartrsturbo
You could try ringing jamsport and asking them to see if they could help you out
Old Aug 22, 2013 | 07:02 PM
Jay,'s Avatar
Jay,
Sponsor
Jamie is the only person i know who will touch these ecu's mate
Old Aug 22, 2013 | 07:04 PM
rhinopower's Avatar
rhinopower
As i found out.... wanted over £500 to map, hence i got megasquirt instead.
Old Aug 22, 2013 | 08:10 PM
Jamie Going's Avatar
Jamie Going
jam-sport.co.uk
why is £500 to much money to map a car
Old Aug 22, 2013 | 08:12 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
It is if you haven't got £500
Old Aug 22, 2013 | 08:15 PM
bigchez's Avatar
bigchez
I paid NMS £500 for a livemap on my 3 door, was perfectly happy with what I got for my cash - well worth it!!
Old Aug 22, 2013 | 08:18 PM
stuartrsturbo
Surly when mapping a car you get what you pay for?
Old Aug 22, 2013 | 08:27 PM
rhinopower's Avatar
rhinopower
I've had live maps done for no more than £300.
Torque of the devil was £240
Power engineering £300
Boost monkeys who are doing it next have quoted £250
All of this was on megasquirt, which lets face it, trumps gotech in every respect.
Old Aug 23, 2013 | 09:59 AM
rsmark86's Avatar
rsmark86
I know Jamie and I know he will sort me out, he's a good lad, I was just hoping I could just having it running correctly before taking it as they are 100 miles each way for me, so just want to book in, get mapped and go with less chances of problems
Plus I know the gotech is differcult to mapp hence not a lot of people wanting to use it, so what Jamie quoted me sounds pretty good
Old Aug 23, 2013 | 10:07 AM
rsmark86's Avatar
rsmark86
How much does you full conversion cost with complete loom, ecu, relays, plugs, mapp ect? Just want to compair?
So far mine is wired up with correct braided loom and mfi pro ecu with 3 bar mapp sensor and launch set up and owes me £275 so with mapping its still a cheap conversion
I looked into ofam as I was running ofab but my loom was shot so with the £389.99 + upgrades and loom repaired it would have cost me a lot more, which is a shame but I'm chuffed with my set up and can't wait to get it mapped
Old Aug 23, 2013 | 10:29 AM
rhinopower's Avatar
rhinopower
Ecu was £150 second hand. Soldered a plug onto my original first time round but have since replaced with a new loom for £70 I think. £60 for a bigger map sensor and boost control. Plus mapping as stated. All the original car relays and bits were used as they didn't need changing.
Old Aug 23, 2013 | 06:14 PM
rsmark86's Avatar
rsmark86
Sounds good, buying a second hand unit saves so much money
But I couldn't buy a ms ecu second hand unless there was proof it was built by a professional, too many DIY guys messing them up
What car is it on?
Old Aug 23, 2013 | 08:47 PM
studabear's Avatar
studabear
What car is it on?
No guarantees buying from so called pro's, I've had trouble with mine, it was built wrong, have now found the boost control wasn't added and the fan control looks to have been wired in wrong. But extra efi say they have never made a mistake.
Old Aug 23, 2013 | 09:35 PM
rhinopower's Avatar
rhinopower
Surprises me! But then there was some dodgy work done on mine by james murray too but boost monkeys took care of fixing other peoples mistakes for free, and upgrading mine. Top bloke!
Old Aug 23, 2013 | 09:36 PM
rhinopower's Avatar
rhinopower
What car is it on?
This was on my throttle bodied st170 engine first, and now my focus rs engine.
Old Aug 24, 2013 | 03:10 AM
rsmark86's Avatar
rsmark86
says it all about the megasquirt world really.......
thank god for Rob at boost monkeys then
did the ecu have full control over the vvt or just activate it at a set rpm? the gotech i have has the outputs for vvt but im guessing it just activates it ?
Old Aug 24, 2013 | 05:24 AM
rhinopower's Avatar
rhinopower
Yeah the gotech just activated it.
Old Aug 24, 2013 | 04:53 PM
rsmark86's Avatar
rsmark86
Thought so
I got a problem anyway, it was off a dizzy powered 1600cvh and I've adapted the loom following the gotech user manual but I have no spark?
There's power at the coil pack and fuel pump is priming, but no fuel in cyclinders and no spark
I'm getting a power probe tonight to see if there is the pulse to it all
Old Aug 24, 2013 | 04:56 PM
rhinopower's Avatar
rhinopower
Open the Ecu. It will say inside what crank trigger it will work with iirc
Old Aug 24, 2013 | 05:19 PM
rsmark86's Avatar
rsmark86
It can be calibrated to work with any including standard but if its set up for a different trigger would that cause no spark?
Old Aug 24, 2013 | 05:42 PM
rhinopower's Avatar
rhinopower
Im sure different triggers needed a different chip inside mate! Will only take a couple of minutes to check
Old Aug 24, 2013 | 05:49 PM
rsmark86's Avatar
rsmark86
With the gotech it's all programable, it's a multi function ecu, for upto 6 cyclinder and can run dizzy or coil pack
I need to check for pulse at the coil pack and injectors tomorrow I guess
Old Aug 24, 2013 | 07:12 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
your 2 systems are totally different, ECU expecting to see Hall effect is getting an inductive input
Old Aug 24, 2013 | 07:47 PM
rhinopower's Avatar
rhinopower
Mark. I had a gotech before so that's why I suggested checking
Old Aug 24, 2013 | 08:25 PM
rsmark86's Avatar
rsmark86
im pretty sure the software is wrong so cant pick up a signal
the previous owner just told me it have a external trigger running dizzy and now i have it wired upto run a wasted spark coil pack with a zetec crank sensor and flywheel, and semi sequential fueling so i need to get the ecu set up for what i have now i guess
Old Aug 25, 2013 | 08:17 AM
rsmark86's Avatar
rsmark86
Your correct, it needs a chip/ software change, so I will make a trip to see Jamie this week and get a base mapp while I'm there
Then it's just sort gearbox and brakes and get it too him for mapping
Old Aug 25, 2013 | 08:18 AM
rhinopower's Avatar
rhinopower
Look on the sticker on top of the Ecu. It will say 60-2, 32-1, MOD. Which one is marked? It refers to the chip inside the Ecu, nothing to do with software settings mate
It should be 32-1 if it's going to work on a ford
Old Aug 25, 2013 | 11:51 AM
Rick's Avatar
Rick
How much mapping are you getting for your £250 out of interest? Cold Start? Warm Start? Transient? Idle control? Boost control?
Old Aug 25, 2013 | 06:33 PM
rsmark86's Avatar
rsmark86
I will check
Old Aug 25, 2013 | 08:28 PM
rsmark86's Avatar
rsmark86
its already got the 31-1 chip in it.......
you will laugh when you hear what i forgot too do lol
Old Aug 25, 2013 | 08:30 PM
rhinopower's Avatar
rhinopower
Im guessing you didnt connect the crank trigger?
studabear's Avatar
studabear
wash behind your ears?
Old Aug 25, 2013 | 08:36 PM
rsmark86's Avatar
rsmark86
even better than that........ the guide i down loaded didnt say anything about grounding the ecu except the ground for the relay to power it........
so.................
i read a few other models of gotech ecu manuals and found that i hadnt earthed the ecu lol, theres two grounds that go straight to the battery and are missing so im going to have to make them up lol
Old Aug 25, 2013 | 08:37 PM
rsmark86's Avatar
rsmark86
na just a reach around and back to front wipe lol
Old Aug 25, 2013 | 08:39 PM
studabear's Avatar
studabear
Lol, glad you've found the problem anyway.
Old Aug 25, 2013 | 08:42 PM
rsmark86's Avatar
rsmark86
ive not tried it yet but must be something along those lines, to be honest dubs44 on here has been a great help and without him i would have given up.......
it was something karlos said that made me and dubs think and pointed to the problem, the manual i downloaded was missing that vital information about the grounds
Old Aug 25, 2013 | 11:25 PM
Rob_DOHC's Avatar
Rob_DOHC
Thanks for the comments guys, I have seen some very 'interesting' approaches to ecu assembly even from the 'pros'.... every one make mistakes but thats what quality systems are there for. Every thing we do gets fully tested and signed off before release and normally this is done by Mike (so someone else tests your work), its backed up further by a year warranty. This has eliminated faulty items being sent out to clients, and is something imo every company producing things (little or large) should do.
Hey Rick long time no speak.
For us £250 is a subsidised price. We don't mind making the mapping fairly cheap as 9/10 we have already supplied the ecu. Further more because we only map pretty select models the cold start, warm up and idle control is 99% taken care of by the base maps we have made for various engine specs. Most only need a few tweaks on the day. Cold start for instance as you know doesn't need to be OEM perfect to work well if you don't care too much about emissions on warm up.
Boost control is setup on the dyno, as is the transient fueling both of which are infenintley simpler on the dyno. Accel enrich for instance takes 10 mins, on the road this can take a whole session, boost control takes a few pulls and then some road testing to confirm.
Leaving the majority of the tuning session to power tuning an part throttle tuning.
To be totally honest 80% of the people that see us have already done the low RPM off boost tuning as well as some on boost tuning, and some do a really good job! Which gives us loads of time to sort out the ign advance tuning etc, this definitely cuts the time an improves the results!
Recently however we did a skyline, we didn't have any base maps for it so it took 2-3 days (on and off) to get to a standard I was happy with, and thats with a further dyno session to go
However (mildly off topic ) the chap with the skyline engine races competitively, with the new ecu and a map which is half way done (low boost) he has already knocked over 1s off his last years best time which im chuffed to bits about!
However we certainly didn't charge £250 for that, so I guess the price charged really reflects the company niche and the availability of varied base maps to start from.
Rob,
