Hi comp turbo engines
#41
#43
Compared to Santa Pod which actually rises around 5 feet from start to finish.
What's laughable about the Honda stuff Jimbo? I see very impressive things with them all the time
#45
Here's a good example:
Or here:
And as for their dyno figures...
#46
Let's not get started on USA dyno figures, if it's not power at the wheels on a Mustang/Dynojet rollers they're not interested. They hate 'our' calculated flywheel figures too.
#48
You can't argue with their terminal speeds?
I do think a lot of their strips are downhill. Not sure how much difference it makes, could an uphill track aid traction? They use fully prepped tracks too.
#49
I would want more power if I was to build one though...so wondering, if I was to build one from ground up - aftermarket rods, pistons, valve train, cams etc (basically anything that would need to be uprated for over 500-550hp)....would the B18 be a good starting block or a K20...or even a K20/24 frankenstein hybrid thing lol
#50
8.5:1 is high for a cosworth pushing the RPM and power levels of Rods car and its been reliable, other than Rod taking it over the 8500 limit regularly to 8800
the WRC engines run higher compression still
From what I understand Jap cars can run much higher compression due to the engine's geometry (eg stroke and bore ratios), plus having the vtec means even higher compression because of the cams.....but might be totally wrong
#51
Thats some seriously impressive figures from stock engines...
A friend of mine is currently running the highest hp stock sleeve b-series in the country at 553whp (so 600+bhp) and has run 70+ low 10 second passes with it so far this season.
I've rambled a bit, but basically to answer your question, for 550bhp you'll need a set of pistons and some rods. Everything else can stay oem Honda.
#52
Hi Amar. For that kind of goal I'd start with a B-series in either 1.6 or 1.8 form. Ideally a B16b from the type r. For only 550bhp, completely stock head, crank and gearbox will be more than up to the job. The first thing to hold you back (engine wise) will be the stock sleeves - any more power and you'd need Dartons or Abrams etc.
That is impressive!!! Is the B18 just as good? (I really fancy an integra you see), but I don't know about tuning as they seem to be pretty highly strung from the factory, does any N/A tuning really work on them?
#54
Ben
Yes, they flow huge amounts of air as standard and there's room for improvement. Lairy VTEC killer cams and big ITBs and you're laughing.
#55
Is that so I dont know you but get your facts straight. 3 of the 8 fastest runs runs ever by a Cossie are down to a pensioner
lets wait till you are 68 a see what you can do.
Im 22 years older than Mark , he will always be quicker than me like he is quicker than MADAde in his own car. Get a bit fed up with this shite from kids that barrack from the sidelines & do jack shite so STFU.
You get stick from people because your a pensioner that trolls this forum amongst other things, points flaws in everyone else because you think your some sort of god.....
#56
hi my xr4i turbo was a stock engine that i put a janspeed turbo kit on and was 258bhp at 7psi of boost was a fast car and good strong engine
#57
Balls Deep!
Your all talking about static compression ratio's when what determines the boost you can run and ultimately the power you can make is the dynamic compression ratio... This is determined by many things including cam profiles as someone did mention.
Two car's can both have identical static CR's but vastly different dynamic CR's, meaning one car will happily run 2 bar but the other only 1 bar.
#61
The annoying ginger guy
As said you have to take in consideration so many factors as not all engines even see static CR while running due to advanced/retarded timing
#63
When VVT comes into it and alters the timing either way the CR will change due to when the piston is on its up stroke as it hits TDC the VvT will alter the cams to make the valves either fully closed or starting to open/near closed which will in turn change the CR
#66
#68
I ran 18psi all day long in my old mb6 vti-s (b18c4) and it had nothing done to the engine at all. The only thing was an oil return and an uprated clutch and a full remap. No idea of power output as never had it on the dyno but must of been close to 350bhp.
#69
Balls Deep!
Take two identical engines fitted with different turbo's, one has a big fuck off turbo and the other a much smaller one, they will both flow for 300bhp yet the engine fitted with the smaller turbo detonates long before it can make the 300bhp target, why is this?
It's because the engine fitted with the smaller turbo has a higher dynamic CR, it's smaller exhaust housing raises back pressure and as a result the dynamic CR (temps too) making the engine more prone to det.
#71
As an example:
![](https://passionford.com/forum/images/smilies/roi.gif)
#72
If your interested to learn, then here you go, a 3 part technical article I wrote all about it.
http://www.motorsport-developments.c...AF265_tech.pdf
http://www.motorsport-developments.c...AF266.tech.pdf
http://www.motorsport-developments.c...AF267_tech.pdf
#73
No - far more.
If your interested to learn, then here you go, a 3 part technical article I wrote all about it.![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
ekjim
17-08-2015 08:57 PM
