T5 is this f**ked
can you not take the top cover off and have a look at the inside of the area if it was cracked i would expect to see oil weeping out that area,i still think that is only casting marks
st170 breaking
If it were damaged it wouldn't crack like that
Just the usual out of view shit casing joints
Give it a good rub back to see but you cleaned it so you can see if it was covered in grime from years or if it had oil seeping out of it
pulled the top off and its cracked right through around the filler plug, maybe someone tried to hammer plug loose is all i can think of.
Is it likely to spread also what oil that was left in box was very metallic looking so maybe i'm better off trying get my money back
was it a local buy?may of come out of a damaged car,being a welder i have repaired cracked block&gear castings etc in the past but if the oil is metallic looking then the bearings&gears have had a hard time in its past,so might be best of just getting a box re build by a know person then you will know you have a good servieable box,as most T5 boxes have have a more than hard life by now!
Good news getting me money back so ain't to bad, Think tibeam is right might just get a mate to rebuild mt75 with new syncro's and bearing and hope it stays together
