Sierra Cosworth 3dr Burnt :(
Scorpio 24v Saloon
HI all
Some of you might have already seen it but for those who havnt seen it.
http://www.copart.co.uk/c2/individua...Type=onSaleNow
I think the bid is on 325 atm.
Anyone interested in it?
Dan
Dan
3dr Cosworth owner
Id say the seats are intact. Doors boot etc. Underneath running gear like axles gearbox hubs etc. Engine block and head may still be ok. Dont suppose the id is of any use being a cat b. Probably still a good few grands worth of salvageble bits to someone who can be arsed stripping every last thing off it
Depends on the heat produced but the alloy head maybe finished.
Rich
Its a lot of work Glenn, you need to bead blast the metal right back to bright all over, then spray filler to lose the burn pockets in the metal, and that's assuming the panel has not warped in the heat.
I have salvaged some really good parts from similar engine bay fires, even heads, bottom ends etc can sometimes be ok even if the ancillaries have melted around them.
I would buy it for a grand no problem, but you have to be a registered breaker for a cat B
3dr cossie
11
21-12-2015 03:38 PM
charliecosworth
19-08-2015 02:00 PM
155lee
14-08-2015 11:21 AM
