MG people (ZT 1.8T in particular)
My work mate bought one last week, all good but he said he's noticed a small drip coming from under the car near the front wheel area. So I had a look under the bonnet and noticed that I couldn't see the brake/clutch fluid level and upon shaking it it appears to be empty.
Also his clutch peddle is abit stiff apparently.
Split pipe somewhere? Also is this the reason why the clutch is abit stiff too?
IMO if a hydraulic pipe was split the clutch would not work at all it would just piss all the fluid out within a couple of pushes of the pedal..
If the clutch is stiff maybe the seals on the slave cylinder are on their way out where they have been worked harder due to the extra pressure of the clutch being stiff..
2p.
2p.
That would explain the clutch but what about the fact that the brake/clutch fluid appears to be empty(or certainly in desperate need of a top up)
Mind you I've never had a car that's used any brake/clutch fluid so it shouldn't need topping up at all?
He's got 6months cover on it anyway so that's not a problem but its just good to go back sounding like you know abit of stuff rather than "yeah it's leaking somewhere down there"
the pivot arm for the clutch release bearing will be siezing up
this causes the clutch to get heavy/stiff very common problem with these
as for the fluid all the pipes connected with the brake/clutch fluid are high pressure so any leaks would usualy be quite obvious
refill it, and just trace the leak/drip
Thanks to the others too
The clutch reservoir is above the pedal... its a fucker to get to!
The one in the engine bay is only for the Brakes.... (I imagine its the same place as the CDTI one)
Ok he went to the garage yesterday evening and they said the brake fluid is ok it's just hard to see(although I'm almost certain the level was no where to be seen)
And they said the odd drip he's getting is from the AC, which he's using, so maybe that explains the drips
Hmmm their either fobbing him off or they dont know what their talking about then ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
To be honest i didnt think car AC would wet the floor after using it
mk3ste
17-10-2021 10:09 AM
rsguy
44
29-09-2015 03:29 PM
