1300 ohv to 1600 xflow
soooo...... its a little bit backwards....I have a 1300 mk4 escort two door estate in white, Im looking at converting it to a 1600 xr2 engine from a mk1 fiesta which is about 90 horse power compared to my current 60... so this is the list for my plan.
XR2 1600 motor with a 5 speed box.
bike carbs.
4 branch manifold.
mid spec cam.
and possibly a big valved head and gas flowed.
the only things I don't know where to go with is drivshafts and what other bit and pieces I need to do the conversion... obviously I know ill be going from electronic ignition to the distributor... but id probs swap it over to electronic at some point....
I have chosen this option as it suits my insurance and also suits my work load...
any ideas and thanks in advance
Johnny
bike carbs.
4 branch manifold.
mid spec cam.
Johnny
getting your flywheel lightened? if your down at rebuilt stage get it all balanced , pressure plate too would shock how much that itself is out .
well the point is to keep it old school.....an xr2 engine bolts straight except one mount.....I don't want any electronics at all.....but I do want bike carbs they sound brilliant as well as the other positives to having them
I thought the crank, timing chain area is different from the Xr to the RWD crossflow and possibly the block and oil pickup/ sump. Yes, the heads the same as is the pistons and rods. Good luck with the swop.
chowfornow
14
05-01-2019 09:01 PM
07-10-2015 12:56 PM
track.focus'd
12-08-2015 05:53 PM
