Remember, Be Carefull When Jacking Up Your Car!
ELASTIC BAND
Just a reminder, has been years since ive had a car move / slip on a jack, so was quite shocked, hadn't got it high enough to get the axle stands under yet !
post whore
Happened to me the other day.first time ever.luckily was just about to go under my vxr to secure exhaust and trolley jack/car rolled back slightly and the trolley jack flipped jamming underneath.had to get a scissor jack to jack it back up and remove.eye opener and il never not use axle stands and put a spare tyre or something under there also.
Received 1,044 Likes
very good mate of mine scotty knew him for years jack his american car up he was underneath killed him outright he didnt suffer everyone thinks wont happen to them
ELASTIC BAND
still at least it happened at home, and not at the size of the road with a flat tyre, will just have to carry a trolly jack in the boot now!
ELASTIC BAND
The only car that I've ever had fall off a jack was an E36 M3 with one of those jacks! The wheel was off and I watched as it gracefully fell, coming to a rest on my mrs' car's bumper. That saved it from any damage and I managed to get another jack under before it slipped off the bumper.
ELASTIC BAND
Gary Krishna
I've had a car fall off a jack with me under it before and it wasn't pleasant.
I was young and very, very stupid to think that I'd get away with just doing a quick job underneath without using stands.
Needless to say it was a harsh lesson learned very quickly and a mistake that will not be repeated by me!!
Never has happened to me fortunatly but i think to much into things and when i normally jack a car up i will put just about everything i can find underneath just incase!
had a roadside brake down ,was fitting a supersingle to a trailer so just jacked that axle needless to say not perfect conditions and the jack sliped with me under it lucky the rim was still on or I would of got my face crushed ,days like that make you rethink yourself and how your going to do things !
ELASTIC BAND
ELASTIC BAND
When working on my Granada i ALWAYS use two spare wheels with blocks of wood to support the front of the car and a trolley jack with another block of wood under the subframe as backup
I NEVER use a standard jack unless mega emergency.I know its been said but I also put wheels under even when using a trolley jack.
I remember my mates 2-8 falling on him and burning both of his arms off the pipes and splitting his eye open when it fell off the trolley mounted under the diff.
It split his eye because he turned his head.If he had still had it in the upright looking position it would of probably split his head like a melon.
Standard jacks are bloody dangerous imo,new or old
it really does make you think. I am guilty of working under a car for quick jobs with just the trolley jack. pure laziness. from now on ill be using axle stands. one slip and it could make real mess
just finding my feet
There was a lad on this forum a few years ago died under his discos doing a gearbox job I think and his trolley jack moved
I always use a set of axle stands since as I swear my 3.5 ton jack lowers slowly but it don't do it on stands or it might just be in my head
struggling with reality
At the moment It normally is Axle stands. I have 2 sets and vary which ones I use as the profile at the top is different which ever one suits get the job! When changing engine mounts I worry unless I am next to a jack as well as having the engine hung from my crane as that is only rated to 500kg.
Any way my wife does go a bit nuts unless it is belt AND braces! - post the little one when I dive I am no longer allowed a single point of failure!
It's worked so far!
It's worked so far!
Only incident I've had when under a car was.. Me and my boss underneath a Toyota Hilux, was on two axle stands under the rear axle, wasn't the sturdiest ground but we had little choice. Can't remember what i was changing but had a long 1/2" bar and was undoing a bolt, pulled on the bar and the Hilux rolled backwards off the axle stands! Luckily being a hilux we were both ok. Best bit, it was on the Olympic Park site when it was being built! Would have caused a fuss, it was like a nightmare getting on there to work.
track.focus'd
12-08-2015 05:53 PM
Zoggon
10-08-2015 10:39 AM
