pre cat and post cat lambda
Old Apr 13, 2013 | 10:33 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Default pre cat and post cat lambda
are pre cat and post cat lambda's interchangable
think my pre cat lambda may be on its way out and got a brand new post cat sensor here. could i fit it and see if it works. sensors are identical bar ones a blue plug and others a green plug.
cars a focus rs mk1
Old Apr 13, 2013 | 11:00 PM
studabear's Avatar
studabear
both 4 wire sensors? 1xblack 1xgrey 2xwhire wires? I would say yes.
If the plugs will connect and if the wiring is long enough, some cars have same wiring/plugs on both sensors.
For the cost though I would just replace with a new item.
Old Apr 14, 2013 | 12:15 AM
JOHNDQ's Avatar
JOHNDQ
You will most likely find the muti plugs are different and that the ohm's resistance is different over the heater circuits
Old Apr 14, 2013 | 11:50 AM
vaughant's Avatar
vaughant
Their the same on the ka's,interchanged them loads of times and had no issues.
Old Apr 14, 2013 | 12:51 PM
JamboRS's Avatar
JamboRS
focus rs 1672
the plugs are the same except ones blue and ones green. the thread for plug is the same. im going to try it anyway and see if it makes a difference,then if it does ill order a new lambda from matt lewis
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
Shows & Track Days
Sep 4, 2015 07:16 AM
