Zetec rev/idle issue
Hi guys, when i rev my zetec and totally let off the throttle the revs will drop to about 1500 and stay there for a second or two and then drop to idle, any ideas? ive had all the TPS etc apart so wondered if its the simple fact i havent reinstalled that right?
PassionFORD Member
Yeah sounds like a good place to start as any. Give it clean out with some brake cleaner/degreaser then lubricate it back up again with a bit of WD-40 or some oil. I'm not overly familiar with the details of the silvertop 130s but the idle valve would be located on the inlet somewhere on the underside of it as per the blacktop if it is the same inlet setup. The PCV and pipework are located at the front of the block if the same as the blacktop and go around the side of the engine below the coil pack and behind the inlet.
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
