View Poll Results: Which tyre is better
P zero Rosso
![](https://passionford.com/forum/images/polls/bar2-l.gif)
![](https://passionford.com/forum/images/polls/bar2.gif)
![](https://passionford.com/forum/images/polls/bar2-r.gif)
![](https://passionford.com/forum/clear.gif)
23.08%
Yokohama Parada Spec 2
![](https://passionford.com/forum/images/polls/bar3-l.gif)
![](https://passionford.com/forum/images/polls/bar3.gif)
![](https://passionford.com/forum/images/polls/bar3-r.gif)
76.92%
Voters: 13. You may not vote on this poll
Pzero Rosso or Yokohama Parada Spec 2
Out of the 2 tyres above which is better?
I currently have P zero Rosso's fitted to the rear but I have just got a screw in
the outer edge of the tyre so it will need replacing,
Just wondering if I should replace the Rosso of go with the Spec 2
![](http://i267.photobucket.com/albums/ii298/mar_klee/P130324_143321_zps70984ca3.jpg)
Cheers for the input guys,
I am going to check the tread depth on the other side, If its much less than a new tire I will
replace both with Prada spec2.
A new Rosso tread depth is 8mm I think.
Pradas....
Good on the road in the dry
ok on track... but if they get hot chunks literally fall off
Scary in the wet.. when driving normally.
I really rate uniroyal rainsports!
Adam
Adam
Tony where you been mate, not seen or read anything for ages, lol
I like them but since it looks like I have to replace 1 I wondered if I should just change the pair
The other one is good mate,
You going any shows this year? be good to catch up although Im still not in a Ford.
Driving a Leon Cupra R now
Yeah, I'm buying a V3 Tip off Bill, lol
Niki and Bill offer the same thing,
I wanted to use Rick@unicorn but he is just too far.
The V3 is cheaper than the v2.2. Bill said the one with the billet adapter is better, but its marginal. 10-15bhp gain over stock TIP.
Bill offers Gear based boost mapping which is great aswell.
I'm still on standard exhaust with a cat so no Launch control or Anti Lag for now,
I quite like the switchable maps aswell,
The Vag me7.5 ECU seems far better than the Ford standard offerings,
