Engine conversion.
Old Feb 22, 2013 | 05:52 PM
Jakeyb's Avatar
Jakeyb
Default Engine conversion.
Hi I'm sorta new here lol but ye basicly I have a 51 plate 1.6 focus its had a miltek exhaust system fitted inc manifold and a k&n panel filter fitted I've had every engine focus bare the st and the rs but this is quick I've had 140 (private road off corse ) but now the millage has hit 130 thou so the bottom end has started to knock so was thinking about changing the engine to a 2.0l but apart from the obvious engine ecu key exhaust and engine wireing loom what else would I have to change ? Thanks in advance jake
Old Feb 22, 2013 | 05:59 PM
doga-ot's Avatar
doga-ot
Engine/engine mounts
engine loom/ecu/key/pats sensor you may not need to change the engine loom but will definatley need the ecu and pats sensor/key
clutch
gearbox can use one you have but gearing will be different
exhaust
suspension
brakes
WES
Old Feb 22, 2013 | 06:01 PM
Fil's Avatar
Fil
ELASTIC BAND
1.6 and 140? if so
oh and just by a 2.0 rather than bother with a point less engine conversion , time and insurance costs, over just buying one ain't worth the hassle.
Old Feb 22, 2013 | 06:03 PM
Jakeyb's Avatar
Jakeyb
Wes would I be able to use the 1.6 gear box ? As the starter is on the front on the 1.6 and on the back on the 2.0 thanks jake
Old Feb 22, 2013 | 06:04 PM
Jakeyb's Avatar
Jakeyb
Originally Posted by Fil
1.6 and 140? if so
No one ever belived me till I put 3 off my friends in and it still did the clock with out fail surprised me to be honest
Old Feb 22, 2013 | 06:08 PM
doga-ot's Avatar
doga-ot
1.6 and 140? if so
Speedo prob showed 140 but no way would a stock focus 1.6 with those mods reach 140 legitimately!!
Old Feb 22, 2013 | 06:11 PM
doga-ot's Avatar
doga-ot
bud starter motor bolts to the gearbox so 2ltr gearbox must have it located on the other side! there for if you keep you box use 1.6 starter ifyou use 2ltr you will need 2ltr starter however as Fil said its not worth time hassle money etc cheaper easier to just buy a 2ltr
Old Feb 22, 2013 | 06:14 PM
rs-tuner's Avatar
rs-tuner
Jakeyb's Avatar
Jakeyb
All I no is the cars had the milteck exhaust system and k&n panel filter not sure if its had remap or anything but speedo is correct as my friends Subaru was next to us because he didn't believe it till he sin it
Old Feb 22, 2013 | 06:17 PM
doga-ot's Avatar
doga-ot
Also bud not to rain on your parade but my FRS which was a 1.8lx 4dr too start off when it had original 1.8 lx running gear in before I converted it had, K&N 57i kit,Cams and veniers, double valve springs and head work(ported and polished) bigger leads,tubular manifold,s/s exhaust 3" and a few other bits and it pissed over st170's but after 100 they would pull on me and it only did an accurate 134mph flat out(no I never wasted time or money doing this car I got it this way to convert too FRS) so you speedo may have showed 140 but car certainly didnt do that speed!
WES
Old Feb 22, 2013 | 06:20 PM
Jakeyb's Avatar
Jakeyb
WES
Well if that's the case my car wasn't doing 140 and my friends scooby running 345bhp wasn't doing 140
Old Feb 22, 2013 | 06:23 PM
studabear's Avatar
studabear
Do you know Mo?
Old Feb 22, 2013 | 06:27 PM
Jakeyb's Avatar
Jakeyb
Mo ? Can't say I do
Old Feb 22, 2013 | 06:33 PM
studabear's Avatar
studabear
he's from brum, legendary lambo slaying rst
Old Feb 22, 2013 | 06:39 PM
Fil's Avatar
Fil
ELASTIC BAND
Originally Posted by studabear
Do you know Mo?
the thought did pop into my head
more likely some vauxhall or vw boy, that's bored and is just on here baiting
Old Feb 22, 2013 | 06:40 PM
Jakeyb's Avatar
Jakeyb
Nope but ill pass anybody my car keys if they don't believe me they can get on the m42 for one junction and do it there self if they like with the bottom end knocking (Y)
Old Feb 22, 2013 | 07:07 PM
snoopaloopa's Avatar
snoopaloopa
Defo a Mo Fo
Old Feb 22, 2013 | 07:18 PM
doga-ot's Avatar
doga-ot
bud your 1.6 gearbox would struggle to get you to that speed with a 1.6 engine its not geared for high speed also the zetec is at its best at high revs but not in basically standard form
Old Feb 22, 2013 | 07:20 PM
Jakeyb's Avatar
Jakeyb
Yeye well call me what ever the eff you like ! (Y) I know what my car does so crack on not believing me i simply posted to get sum advice not to get slated cuz dont believe me (y) sad sad people !
Old Feb 22, 2013 | 07:21 PM
doga-ot's Avatar
doga-ot
Also bud I also dont think you realise about ALL FORDS they are not great with calibration and are almost always at least 10mph out once you reach 100mph so if it says 140=130,150=140 etc etc
Old Feb 22, 2013 | 07:22 PM
Jakeyb's Avatar
Jakeyb
How about next time your passing thru brum you pop down and drive it your self (y)
Old Feb 22, 2013 | 07:23 PM
stephenbatey's Avatar
stephenbatey
140 in a 1.6 focus? Birmingham? Mo by any chance?
Old Feb 22, 2013 | 07:24 PM
stephenbatey
Pics or it didn't happen
Old Feb 22, 2013 | 07:41 PM
doga-ot's Avatar
doga-ot
Come to London and I'll race you to if that does 140mph and it is a 1.6 you can have my saph
Old Feb 22, 2013 | 07:44 PM
sidewaysdave's Avatar
sidewaysdave
Lol can I buy the engine? If its that quick get it repaired as it will be quicker than replacing it and what was up with your mates scobby? As it should eat a 1.6 focus!
Old Feb 22, 2013 | 08:03 PM
Jakeyb's Avatar
Jakeyb
I don't claim it to get there as fast as you saffy does ! But it gets there I've got no friggin reason to lie I've raced a remapped fabia vrs and stayed on the arse end off it it couldn't pull away from me
Old Feb 22, 2013 | 08:17 PM
Winky10's Avatar
Winky10
Sorry this I do not believe I've been in a remapped Fabia and they aint slow and there not rapidly fast but it is hard for me to believe that he couldn't pull away from you!
Old Feb 22, 2013 | 08:21 PM
doga-ot's Avatar
doga-ot
As above Im a FORD nut but my old seat leon cupra R with remap tb.04 turbo,manifold,exhaust injectors, k&n would of eaten a focus in any form let alone a 1.6 and its same engine as golf gti turbo and skoda vrs fabia vrs all VAG engines
Old Feb 22, 2013 | 10:25 PM
Jakeyb's Avatar
Jakeyb
Yeye corse it is divvy ! Fabia vrs are diesel prat !
Old Feb 23, 2013 | 07:26 AM
luke19790_3's Avatar
luke19790_3
It's still a vag engine, 130bhp diesel. Would kill a 1.6 focus
Old Feb 23, 2013 | 08:20 AM
MrC's Avatar
MrC
Is there something in the air in Birmingham that makes cars go faster than anywhere else, maybe there's more N2o circulating about to give you that extra shot of power.
Strange
Old Feb 23, 2013 | 08:54 AM
Hobomassiv's Avatar
Hobomassiv
Comedy gold thread would read again.
Old Feb 23, 2013 | 08:59 AM
Smudge374's Avatar
Smudge374
Yeah and some of the Lemans cars are too now! they use them because they are super slow! lmao. good luck with your lambo conversion!
Old Feb 23, 2013 | 11:49 AM
stephenbatey
Strange
Or maybe they just talk a load of shit
Old Feb 25, 2013 | 02:16 PM
Jakeyb's Avatar
Jakeyb
Ye k bunch ov Fukin idiots !
Old Feb 25, 2013 | 04:14 PM
Winky10's Avatar
Winky10
We're the idiots for knowing your 1.6 focus doesn't do 140 with a K&N and a Backbox?!?!
Old Feb 25, 2013 | 05:02 PM
DanCossie's Avatar
DanCossie
Post Whore
Hahaha comical thread...... there must be something in the brummt water cos everyone who drives a ford seems to be a moron lol
Old Feb 25, 2013 | 05:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The reason people dont beleive you is because the 1.6 Focus produces 98bhp and has a top speed of 115mph... Sadly mate your filter and exahust at best will give it 5-10bhp more which is no where near enough to get to 140mph.
But that aside, to answer your question I also think it would be much easier and maybe even cheaper to just buy a 2.0 Focus than to retro fit the engine, ECU, etc..
Old Feb 25, 2013 | 06:12 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
My Fiesta had a full Milltek and a panel filter, it'd show 140mph on the Speedo, down a big fucking hill, but you were doing about 125 if you were lucky. Your 1.6 Focus does not do 140mph, they're not even geared to that at the limiter, but it wouldn't pull to the limiter in 5th anyway!
Mo Mo Mo ya boat, gently off a cliff.
Old Feb 25, 2013 | 06:17 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Fucking LOL'd at this
Regarding the original Q..
It'd be cheaper to just buy a 2.0 Focus.
A car that has been converted to a higher output motor will be more expensive to insure than a car with the bigger engine as standard.
