solid lifters
Old Mar 12, 2005 | 01:10 PM
gus's Avatar
gus
Default solid lifters
are these any good on a escort turbo
thought they was only suited for n/a cars to alllow to rev higher
Old Mar 12, 2005 | 01:12 PM
sf's Avatar
sf
Default Re: solid lifters
ye, ive a set in my s2, id recommend them, ive newman cam wi solids
Old Mar 12, 2005 | 01:16 PM
gus's Avatar
gus
do they not need adjusting alot?
Old Mar 12, 2005 | 01:18 PM
sf's Avatar
sf
prob had them done twice in the last 18 month
Old Mar 12, 2005 | 01:20 PM
gus's Avatar
gus
is it much grief to do
what cam did you get? lift? duration and what not
think he is making mine up to his own spec to suit me engine
Old Mar 12, 2005 | 01:26 PM
sf's Avatar
sf
the s2 i have used to belong to one of my mates,and ava done all the work for him as they fitted and set it all up, its a newman cam thats init,
Old Mar 12, 2005 | 02:49 PM
Ginge !'s Avatar
Ginge !
just finding my feet
newman will only spec a cam to the profile ya give em !!!!, ava are the ones ya wanna buy the cam off as they give newman the spec they want, there good cams too, its about the right combination!!!
how high do ya want ya car to rev to and have ya got steel rods as if not ya car aint gonna need em, on and the adjustment of the solid cams aint like the hassle bollox ya get with the old ford engines, there ment to have spacers or somink that makes em foking easy to adjust , buy a 1.8 sierra rocker cover gasket and ya will be able to remove and re-use that gasket
Old Mar 12, 2005 | 07:39 PM
Depends which ones you have to be honest.
NMS can do a Solid Lifter spec cam too
Old Mar 12, 2005 | 07:48 PM
morto's Avatar
morto
thought thay were only any good if your reving above 6/7 rpm
andzz
Old Mar 13, 2005 | 07:31 AM
Badman38's Avatar
Badman38
i`m using a newman cam wouldnt use any others they last a lot longer then piper of kent i gave him a spec and he ground one for me my profile is a bit more radical then the cvh37 i have fitted three of there cams now i can help you fit it if you are not that confident with adjusting the lifters they do a off the shelf cam for the 1.6 turbo
Old Mar 13, 2005 | 08:40 AM
gus's Avatar
gus
i wont be getting my hands dirty with this
thanks thou
just seeing peoples thoughts on them
Prickly_buzz
Dec 7, 2017 09:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
gambo08
Feb 4, 2016 10:49 PM
mk1turboestate
Dec 2, 2015 08:31 PM
SMILER258
Sep 28, 2015 09:04 AM
