Camless Zetec Valvetrain
Hello all,
I don't own a ford myself well not a running one anyway, got a mk1 escort cabriolet that will one day be restored but thats another story.
I am currently studying a masters in mechanical engineering and for my dissertation I'm aiming to design some sort of system that does away with cams although.
Which brings me to why I'm here... Ive picked up a zetec SE 1.6 cylinder head to use as test bed for the concept. Went for it as it was dirt cheap and figured being a ford there would be loads of information relating to the engine.
However I'm struggling to find real technical details. Got the basics such as bore, stroke and power figures but cant seem to find any real indepth values for the valve train ie cam timing, clearance volumes as well as dimensions of conrods and crank. Basically I going to mathematically/CAD model the current system so that I can then experiment with various different valve lifts and durations for a number of different driving conditions.
Just wondered if anyone knew of any good links or pdfs of technical specs. Would be much appreciated.
Engine Machinist
Hello all,
Just wondered if anyone knew of any good links or pdfs of technical specs. Would be much appreciated.![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
only a guess mind
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
i read that solenoid operated valves would be the next major leap forward in combustion engine technology. iirc it was 10-15 years ago, still waiting for it to happen.
Still not certain which form I will pursue will depend on testing I reckon. Although I'm swayed towards the electro-magnetic and will be faster acting than hydraulic actuators. In the mean time got to model the standard system so I know the forces involved in the standard lift profile giving me an idea of what to aim at.
Yer the Fiat 500 and some alfas run a system that they called multiair, works but using a mechanical linkage from the camshaft through a hydraulic cylinder that by varying the pressure can control the lift of the valves. Its a clever system does away with a throttle valve as well which helps reduce pumping losses. Theres a good video here explaining the principle. There are a few companies that have put various variations into production although most still require a camshaft, Id like to design a system that has no cams at all and is all electronically controlled. Its something that many manufactures are very interested in developing, part the reason I chose it.
If changing your base model to a 1.8 blacktop zetec is an then I have everything you need from blueprints cad models, optimised gt-power simulations, the fiat multiair engine still utilises a camshaft to control cam timing so not really feasible. Have you looked into rotary pulse supercharger as a means of loosing the valves? Let us know how you get along as I am working on a similar concept.
Not looked a rotary pulse supercharger will look into it, writing up some of my research today so will add a chapter in for it.
What is it your working on if you dont mind me asking?
Ill send some stuff across what's your email, I'm designing a revised eco boost engine without valve springs with a very high limiter lol I also have run some cfd simulations on the zetec ports that may also be of interest to you if you have the software to view them?
![god](https://passionford.com/forum/images/smilies/dieu.gif)
I have Ansys CFD package installed so can open and run cfd analysis.
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
