biggest disc under a 15" wheel....
Originally Posted by BillyCabrio
Yep, all you need is 4x1mm washers to offset the calliper slightly and away you go.
If your using the 4x4 callipers tho, the 2wd callipers are a pain in the arse.
whats the difference between the 2?
i'll be using 2wd front calipers
The 2wd callipers are 4 pots and the 4x4 callipers are 2 pot.
The 2wd ones you have to get seriously modded by an engineering place to get them to the right offset for the rim to fit, the 4x4 ones - all you need are the 4 shims as i said above.
A damn site easier and SAFER! No skimming off the calliper down to an unsafe standard, as theres a possibility it could crack - it is only cast metal after all.
If i were you i'd go with the 4x4 callipers and 2wd discs.
Originally Posted by BROM@ZOO
depending on wheels 300mm
Whoops this is faye btw lol
no worrys faye i kinow the ford 7 spoke rs rim is a bastard of a wheel to fit
i fitted 330 brembos under the 17 inch rs rim
and 315s under a rs mondy rim
motorsport rims deffo 300mm
some road rims then maybe
Rad don't lie ya talking about ya mini,,,,so no they won't fit
Fook me it would look like a set of discs driving down the road,,,,however you could start a new trend
x x x
x x x
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
