Is this a Escort mk5b change over year?
Is the mk5a just the early mk5 with the slatted grill, 1990 to 1992?
IIRC in terms of variations of looks, there was the first one with slatted grill then this one with the oval 'mouth' lol then it changed to the smooth one piece headlight mk6.
Reason i ask all this is i'm trying to find what clutch release bearing to use for a ib5 box using a rst ap clutch and some have quoted on various threads a mk5b change over year, hence this thread lol
I might be wrong here but aren't rst clutches compatible with mtx boxes and flywheels not ib5? I vaguely went down this road when I had mine years ago is the rst clutch 220mm and ib5 210mm or something daft like that?
I can't see why you want to use an ib5 box with an rst clutch unless its turbo'd? In which case I really don't know why you're using an ib5 they're utter shit and made of chocolate
RST uprated clutches are fine with the ib5 if you use the correct flywheel.
Its the mk5b change over year release bearing that's the issue. Need the part number for this recessed version as per pic below.
Here's a facelift on a L plate, guessing 1994?
http://www.kintyreforum.com/viewtopic.php?f=9&t=1734
Googled K plate mk5 Escort and a couple of Vans popped up with the same open mouth grill front end.
steerfromdarear
28
29-01-2016 06:14 PM
ekjim
17-08-2015 08:57 PM
