Engine mangement
Old Dec 30, 2012 | 10:16 PM
Slik Johnson's Avatar
Slik Johnson
Default Engine mangement
Had a ignition problem with my 1.8 Focus Zetec which is now sorted but the engine management light is still on. All ive done is change the leads and plugs as the old ones didnt connect properly and made it run on three cyliders. The engine management came on as i was on my way to change them but now it wont go. What do i do?
Old Dec 31, 2012 | 09:26 AM
studabear's Avatar
studabear
needs reseting with a code reader, not sure if a battery disconnect will do it, google may confirm.
Old Dec 31, 2012 | 09:56 AM
RichieST's Avatar
RichieST
Disconnecting the negative lead off the battery for 10 mins will do it, or I think about 20 on / off cycles of the engine and as long as the fault doesn't reappear it should go out, but the code will stay stored in the ecu and it might stay in limp mode.
Disconnect the battery for a bit will be your best bet!
Old Dec 31, 2012 | 12:45 PM
Slik Johnson
Jumped in the motor today and the light has gone. Job done. Thanks lads
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
