Wiring in a Ciggy lighter socket for ignition on position?
Hi Guys,
My ciggy lighter doesnt seem to work and I need something to power my Road Angel! In my old car I had a 2 way ciggy lighter adapter running from the stereo circuit so it came on when the ignition was on! I have tried to do that in the Series 2 and it doesnt seem to power up
Does anybody know how else I can fit a ciggy lighter port?
Thanks
Thanks
The fag lighter on the S2 are perminantly live, even when the ignition is off. I'd check the wiring behing the socket and make sure everything is connected properly.
Also if the socket its self has been used by a smoker chances are its all clogged up. Get your self another socket from a parts store (halfords do em) - They're easy enough to fit, just a little fiddly getting the old socket out and the new one in.
Thanks
I want to be able to wire it in so it only comeso n with the ignition so I can plug all the Road Angel / Phone Charger wires neatly behind the dash. If it use it perm live then it will flatten the battery
Originally Posted by EssexBoyRacer
Wouldnt u be better off hard wiring the road angel in then? Using an ignition live supply?
does it not come with a seperate "hard wire" kit?
u can be an "inline" fag lighter socket which u could then hardwire into the dash. Which means you wouldnt have to cut the fag lighter plug on the road angel, but it would all still be hidden behind the dash - also means you can take the feed from an ignition supply.
Nah it just came with the ciggy lighter plug
Originally Posted by Lee @ Fusion
the yelow wire on the ignition switch is the ignition live ,
but u probably knew that anyway
So if I snip into this and run a wire to the live on the ciggy lighter adapter it should work fine?
Thanks
actually, thinking about it if u're keeping the fag lighter plug that will be fused so u dont really have to worry.
but it wont hurt to put one in anyway. I'd say to match what ever fuse is in the road angel fag plug.
spot on mate , every tme you turn the ignition on the lighter socket/ your road angel will work .
I will get some wire etc at the weekend! I hate driving a faster car without the road angel
Mark RS
12-10-2015 06:01 AM
