Granada hubs on a sapphire...
Cornish Fasty
is it possible to swap 4x4 granada 5 stud hubs onto Sapph Cos?
i've found some wheels i really want, and 5x112 granny hubs makes more sense than pcd adaptors...
Resident Wrestling Legend
yes, it's a straight forward hub swap if you simply undo the big hub nut
however, with the inherant problems you may face, and the cost of changing the bearings as well as the potential for the hub nuts to strip the threads on the shafts, it may be easier to simply get some brackets made to get your brakes to fit
I quite fancy 5 stud hubs just to be different but...
Did Granada/Scorpio 4x4 models get 5 stud wheels?
If they did, are the hub flanges a straight swap onto Sierra Cosworth 4x4 hubs and driveshafts?
If the didn't, can I use rear flanges on the front for Sierra Cosworth 4x4 hubs and driveshafts?
My mate had his 500 converted to 5 stud ( keeping all the original parts though I might add )
Same story though, got some BBS split rims in 5 stud and had to have them on his car along with the 330mm 4 pots
![Name: 5196c372.jpg
Size: 299.3 KB](https://passionford.com/forum/attachments/general-car-related-discussion/178804d1502131792-granada-hubs-on-a-sapphire-5196c372.jpg)
![Name: 7b4ae28c.jpg
Size: 270.8 KB](https://passionford.com/forum/attachments/general-car-related-discussion/178805d1502131792-granada-hubs-on-a-sapphire-7b4ae28c.jpg)
Certainly looks epic on them !
