cossie rear trailing arm bushes how the chuffin hell
proper cossie trailing arm "bushes" are spherical bearings rather than compliant (rubber etc) bushes. The centre sleeve SHOULD feel free to pivot around the centre, but shouldn't be any side-side or front-back slack. The fact it is free to move doesn't mean it's worn!! Only needs replacing if there is side or radial play.
If you really do want to get them out it will need a press.
![](http://www.ridetech.com/productinfo/cat04images/skw008.jpg)
they are pretty much like these inside, but with rubber dirt seals each side.
The bit in the middle is essentially a ball, so you can see how it will swivel in all directions but not move sideways or front-back..
mine on the cossie were a bastard to get out, in they end they set fire to them using oxycesolene (sp) then when they melted enought they just fell out and the new 1 pushed in easy and a few mins later when it all cooled down the bush was in there nice and tight.
He spent 2 hours with a big hammer and an air chisel first off and got nowhere with it.
jessie_rs
11
03-06-2019 04:57 PM
09-10-2015 07:38 PM
155lee
14-08-2015 11:21 AM
track.focus'd
12-08-2015 05:53 PM
