YB problem
Old Nov 4, 2012 | 03:09 PM
flyboy's Avatar
flyboy
Default YB problem
I have a problem with my YB. The car starts and runs ok for 3-5 mins. I can then hear the fuel pump whirring. The whirring stops then the engine dies. It starts again after a couple of mins then does the same thing again. Any ideas?
Old Nov 4, 2012 | 03:58 PM
dug112y's Avatar
dug112y
passionford pro
are you saying the fuel pump stops working?daft question but is there plenty fuel in it? how handy are you with electrics?? if yes then get a test light or voltmeter across the pump terminals to see if the feed or earth is dropping away after 3/5 min running. if yes you need to start looking in the direction of fuel pump relay/associated wiring or possibly ecu (ecu controls relay). you could hard wire the pump onto a battery as a test to make sure pump is ok and see if the car runs for more than 5 moin.
Old Nov 4, 2012 | 05:55 PM
cossiedad's Avatar
cossiedad
Sounds like the fuel filter could be full of crap and only allowing enough through to run for a short while ie the flow is restricted so after a few mins of not running it has enough to run again. Cheap fix to try.
cheeRS
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
