key coding
Old Nov 2, 2012 | 07:46 PM
northernmonkey's Avatar
northernmonkey
I didn't do it!
Default key coding
I don't suppose anyone in kent is able to code a ecu to a car?
I thought i'd ask on here, you never know who might have ids or similar laying about! lol
Old Nov 2, 2012 | 09:00 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you have to code the key to the car, not the other way around
Old Nov 2, 2012 | 09:53 PM
northernmonkey
I didn't do it!
the key is from the car, but it had the ecu 'repaired' (that's another story) and now pats is coming up with ecu id mismatch, and therefore needs recoding. I don't know/care how it's done, but i'm led to believe ids will do this?
Old Nov 3, 2012 | 06:21 AM
dojj's Avatar
dojj
ids is the ford way to do it which will work
you can recode the keys yourself, but you need to have a key that works first apparently
there is a sequence to turn the ignition on and off etc to recode it but it varies from car to car, i know my mondeo needed it doing but the fiesta was easy enough to sort
Old Nov 3, 2012 | 09:09 AM
Miller 3's Avatar
Miller 3
Where in kent?
And how urgent is it? as i have an ids and key coding computer at work but where im a mobile van i dont have it all the time.
What car and year is it?
Old Nov 3, 2012 | 06:01 PM
northernmonkey
I didn't do it!
Originally Posted by Miller 3
Where in kent?
I'm just down the road in Faversham mate, its a 2003 fusion (fiesta) however, I sent the ecu back via royal mail and it appears not to have arrived there yet. I was hoping they'd have a back up of the ecu code and be able to rewrite it.
So, as for urgency, not at all! Lol
Dojj, thanks for your help, but it's the ecu that's lost the code, therefore non of the keys are registering.
Old Nov 3, 2012 | 06:25 PM
dojj's Avatar
dojj
have you tried swapping the transoponder ring around the steering colum?
Old Nov 3, 2012 | 07:55 PM
northernmonkey
I didn't do it!
dojj it went off to the ecu repair after the coil pack went and took the ecu with it, came back, plug it in and it ran perfectly but had no speedo or mileage display (i've since suspected the vss) so it went back. Upon it's return, it has an immobliser problem (dash pats code 2-3 ecu id mismatch), I've sent it back again and it's somewhere in royal mail's system, I'm hoping it ain't lost!
I'm pretty sure therefore that it's lost it's ecu coding mate.
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Flatlinedan
Sep 18, 2015 12:41 PM
NC53
Sep 13, 2015 03:05 PM
