Which Honda or yaris coil on plug works with the cosworth engine???
Going down the coil on plug route on my cosworth yb engine and although I know they fit and work there are so many options
So who has them fitted and running on there engine? Ideally with a photo to show if you milled the castles off the cam cover to fit them and what model and year car they came from with full part number
Any help appreciated
Thanks
Marc
Thanks
Marc
Thanks
Marc
Thanks
Marc
honda cbr motorcycle ones are what julian godfrey uses ,look on that engine at £62,000 that has then on denso ones
mark
I think it was Martin Hadland that used them on a cossie as well but need to have a search and find out
Thanks
Marc
Marc,
Have a look at this on the MLR,
http://www.lancerregister.com/showth...=389567&page=4
Some on there are using these
http://www.ebay.co.uk/itm/TOYOTA-YAR...-/320770937652
HTH
Ian
HTH
Ian
I had a read thanks Ian, not sure if the lengths will suit a cossie head though so need to measure a standard cossie plug lead then go breakers and measure a cop to check they are the same
Also some like the Yaris are 4 pins and the like of the Civic type-R are 3 pins on the connector
If you go down the yarris route, the hardest bit for me was finding the connectors, i ended up after trawling for hours with this place in the states. Very quick servive though, i recieved mine within a week-10 Days.
http://www.szabaga.com/store/diyconn.html
Yeah I am going to take a cossie lead but did not have 1 a the time so was stumped and didn't want to spend out incase I got it wrong so will go back with a lead Monday
Pacificzetecturbo - what length are yours from under the flat top to the plug end? Is there a part number on yours? And are they 3 or 4 pin versions?
Thanks
Marc
Thanks
Marc
Thanks
Marc
Thanks
Marc
The part number on the coil pack is 1AC08285
It is 11.3mm from under the round plastic part to the tip of the rubber sleeve that pushes over the plug. Once we milled the round raised section of the rocker cover level with the rest of it we went down a further 4mm. The measurement round is 47.5mm this is to allow for the rubber that comes with it you can turn over and it seals in the hole. Hope that helps.
Thanks for all your help and info guys, it was very much appreciated ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Matt Baxter - I found the same coils as you in the end, so going to use them,
![Name: CDAF2592-3A0B-4333-870E-7F36BDC670B5-785-00000099887297CA.jpg
Size: 369.1 KB](https://passionford.com/forum/attachments/general-car-related-discussion/143042d1501884623-which-honda-or-yaris-coil-on-plug-works-with-the-cosworth-engine-cdaf2592-3a0b-4333-870e-7f36bdc670b5-785-00000099887297ca.jpg)
I see you milled your castle off the cam cover to get them to sit at the correct height but did you mill them flush or recess the hole at all?
Do you have a photo of the cam cover with cop's removed?
Many thanks
Marc
Many thanks
Marc
The best Denso COP's to use are 90919-02230 off an IS200 as you wont need to machine the castles off as they quite long.
But you could just use an M4 Stand off to increase the height of the spark plug itself.
![Name: SparkPlugExtension.jpg
Size: 230.0 KB](https://passionford.com/forum/attachments/general-car-related-discussion/143043d1501884623-which-honda-or-yaris-coil-on-plug-works-with-the-cosworth-engine-sparkplugextension.jpg)
Also no need to drill and tap the cam cover as the cam cover bolt holes line up perfectly with the hole in the COP here is a 90919-02230 rested on my Cam Cover the orientation of the plug is perfect too facing backwards towards the bulkhead.
You'll just need a small bit of M8 Alloy tube to go under the bolt hole so it doesn't pull it down on the piss when you tighten the bolt up.
![Name: CossieCOP.jpg
Size: 200.8 KB](https://passionford.com/forum/attachments/general-car-related-discussion/143044d1501884623-which-honda-or-yaris-coil-on-plug-works-with-the-cosworth-engine-cossiecop.jpg)
90919-02230 are only £29.75 each brand new off of eBay:
http://www.ebay.co.uk/itm/LEXUS-IS200-IS300-IGNITION-COIL-PACK-90919-02230-/180827988340?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item2a1a302174
Rich
Rich
For my personnel build I prefer the castles machined off so the coil on plugs are as low as they can be purely because it looks nicer and my whole build is based on how things look as well as perform, also I don't really like the idea of extending the plug as you have added a potential failure point to the plug that is not necessary, I'm not saying it doesn't work I just think it's a bad solution to an unnecessary problem,
Good choice of cop, very tidy that way it lines up with the cam cover bolt holes, although from what I have read its best to avoid any pattern parts and stick to genuine Denso items
Thanks for the info on the thread though as this is all good info for people looking to go down this route
Thanks
Marc
Thanks
Marc
Is that a little tight when you fill the oil on it?
I suppose unplugging the packs no real hardship.
How are these driven? By modding the ign amp or just new management?
Mines a 1990 4x4 so I think l6(????).
I fancy these as their more reliable.
Thanks
Marc
Thanks
Marc
You can get genuine Denso COP in the afore mentioned part number for £33.99 delivered.
http://www.ebay.co.uk/itm/GENUINE-LEXUS-90919-02230-IS200-GS430-IS300-LS430-IGNITION-COIL-PACK-PENCIL-NEW-/221145552322?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item337d4d55c2
Rich
Carbon Crazy
I'm running Vi-pec which has the coil drivers built in to the ECU.
can these be fitted to a big turbo escort cosworth and be run off the standard P8 ECU with wasted spark (coilpack) option by MSD.
If so does anyone have a wiring diagram to do it. thanks.
Hi folks. Sorry to dig this up again but i just need a bit of clarification as im going down this route myself.
The cover i have has been milled so the castles are flush. Am i right in thinking that the Yaris coils need a standoff whereas the 90919-02230 Lexus coils do not?
In the process of (slowly) building a YB to hopefully put in a MKII Escort at some point so im sure i will be asking plenty of questions?.![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
TT
TT
TT
TT
Thanks
Marc
