pinto power help
hi there i have 1986 ford capri mk3 2.0s its my first car and im looking to try and get more power out of the 205 block and im looking for help to tell me how to get more power i cant turbo it as insurence wont like that and i belive the standard power is 101bhp and was wondering what sort of power i can get out of it and still use it every day thanks for reading blake1992
find a good big valve head complete with suitable cam and a set of twin 45's and 150 real bhp all day long with a good 4 branch exhaust manifold and system
steve
steve
well i fitted everything new to my cylinder head with a fast road cam and twin 45 dellortos fitted to my 2.0l pinto and tbh didnt see a huge difference in power, id say save your money for a different engine in the future
Depends on your budget, capri 3.0 carb, decent air filter, 4-2-1 exhaust manifold and decent exhaust should see 120ish, if you can afford more, get the head ported, high lift cam (rl31 is a good fast road profile) and some headwork should see a bit more. Then your in twein carb territory, twin 45s, ported head head with bigger possible bigger vales, and by now I'd say some work to the bottom end (a good balance, possibly bore it out to 2.1 litres with cast pistons) could see as much as 165bhp. That will give a great fast road engine. If you can afford it, you can get 220bhp out of a 2.0 for Ł12k! Or even more with a long stroke crank, injection and race fuel, fuck it, go all the way and fit an alloy bottom end and take it to 2.7 litres!
in my opinion and from what ive done with pintos so far they really are not worth modding unless your willing to put thousands and thousands in to get next to FA in return when it comes to money to bhp value, in one sence it would prob work out cheaper to drop in a standard ford v8 engine in that hits 200bhp without any mods prob costing you around Ł1000 depending on engine and skills/capability of fitting it yourself
This
http://www.ebay.co.uk/itm/Weber-38DG...item3ccad6de6f
and this
http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
and a good serivce, you know plugs and all that. Job jobbed
and this
If you mate has a 2.8 then get that lump from him for the pistons. Take your lump out and rebuild your bottom end and bore out to 93mm (i think) and use the v6 pistons. Cheap, only cost about 60 quid to be bored plus shells and rings.
Spend the rest of your money on head work. Something has to be done with the rods? I sure someone can tell you what.
If you've only got 400 to spend your best bet is ebay, second hand ported head, 4 branch +exhaust, K&N and rejet standard carb.
It'll make about 125 if your engine is in good nick to start with
not as straight forward as that think you have deck the block aswell to get compression right and narrow small ends i think,
Edit: Put some picys up of it.
i will do i oly picked it up yesterday i kinda felt sorry for the man he had tears in his eyes but his wife had enuff of the car so made him bye somthing newer he loved the car it had been garged most of its life up un till 2 years ago i herd he was selling it as ive known of the car for about 10 years witch is half my life so i offerd him 650 and he said the min he would take was 950 but i got him down to 875 when i got it home i felt like i robbed him but i dunno if its about right for the car or not
http://www.ebay.co.uk/itm/FORD-CAPRI...item2576b7d43d does amy one no of any of these type seats but with the blue stripes and looking for blue s decal set
To be honest with your budget I would just give it a full service, get a 4 branch and exhaust on for a better soundtrack and take it for a set up. Wouldn't bother taking the head off, having it worked and cammed etc etc. Not for the gains you will see. Unless you spend big bucks I don't think you'l get the power you hope for. Also sometimes people feel they need more power and never change gear over 4k rpm. Give the girl some proper revs and see how she feels!
to go with gjh post of 3l carb and k&n
http://www.ebay.co.uk/itm/Ford-Pinto...item4abd71e260
all you need find then is a four branch manifold.Not a lot spent and should go quite well for pennies
I think considering your budget, the "fickleness" of the pinto to cams, the already large size of the ports, the milage of the motor and the cost effectiveness and limitations of modifiing the motor i would agree with the posters who recommend leaving the head on and the block alone.
on your budget 2 twin-choke 45mm side draught webbers would give a good improvement, a bigger single doundraught webber would look very similar to whats on now, if the carb is blended/ matched/ gas flowed to the inlet manifold (and the manifold to the head) it can make a big difference, the air filter is poorly designed and restrictive an encapsulated cone filter/ CAIS helps (PX venom etc) or an open carb with a cool air feed
you will need to re-jet set up the carb/s and it helps if you have someone who knows what they are doing for this
you could fit colder plugs (stock are a bit hot IMO) this would allow you to run a little leaner for better MPG (modded pintos can be gutsy brutes)
the above and a better exhaust would be sensible mods probably within your budget
even if you had money to burn, i feel it would be better spent on a transplant (a 3.0 or 2.8 v6 springs to mind) than spending ŁŁŁŁŁŁŁŁs on the pinto
the volvo/ focus ST 5 cylinder turbo kicks out about 225bhp stock and can easily (and realatively cheaply) be made to put out 300+ - that would be an interesting project, the 2.0L t cosworth engine would be another very sensible option rather than spending silly money/ time/ hassle rebulding the pinto block/ head for realatively small returns
i had a 1.6 pinto saph
wanted power so i bought a 2ltr pinto, fitted twin40 carbs, newman road cam, skimmed head, twin throttle linkages
she goes well, but imo a waste of money
they sound great, but thats about it, i spent a clean fortune
webbers Ł300
cam an followers Ł100
head skim an gaskets Ł70
2ltr pinto Ł100
twin linkages Ł80
an there's still loads i can do
webbers Ł300
2ltr pinto Ł100
twin linkages Ł80
TBH the best thing you can do is save up more, pintos are lovely little engines and sound great on a set of carbs, so I'd deffo keep it, use it as it is for now until you have enough funds aside to give it a good going over (headwork, cam, carbs, possibly rebore, exhaust etc).
not worth it in my opinion, (why bother) may as well stick with the pinto if its only 2.0L (the same capacity as the pinto) + your pinto has only done 25k, if you are going to fit a Colone V6 you would be better with the 2.8i
