Newman Adjustable Cam Followers
Old 09-10-2012 | 03:40 PM
Stevie RS Boy's Avatar
Stevie RS Boy
Default Newman Adjustable Cam Followers
Now what is the best way to adjust these? doing my cvh head at the moment, Do you do the clearance between the end of the valve and rocker arm, or under the rocker arm and cam follower? also will the fingers rattle when done as before they use hydraulic tappets and they keep abit of tension on the arm
Old 09-10-2012 | 03:42 PM
STeve's Avatar
Moderator
great set up the newman cam and followers but a right pain in the rear to get set up in first place hence why most simply drop in new hydraulic ones
Fezman1
02-10-2015 02:22 PM
Quick Reply: Newman Adjustable Cam Followers
