Best brake upgrade for xr4i
What would be best for xr4i? Mondeo 300mm front brake conversion or 2wd saph 4pot brakes?
What's the advantages if either one?
What would be easiest? Would I need to change hubs or brake cylinder?
Also to put cossie brakes on rear what parts do I need from a cosworth?
Cheers Ben
Cheers Ben
best to upgrade to a xr4x4 rear axle. if you want to upgrade to rear cossie brake you will need the hub carriers.
on the front mondeo callipers are good, but you can fit bmw e38 front callipers(brembos) and use focus rs mk1 discs. you will need calliper brackets( i used some from caprisport).
Cheers yorevol. So it would be cheaper swap from a xr4x4 rear than it would a cossie set up.
Brembos would be nice but more than I wanna spend at moment and I've only got 16s so be a tight fit. Cheers
