master cylinder adjustment.
Old 19-09-2012 | 08:16 PM
mgtkr1's Avatar
mgtkr1
Default master cylinder adjustment.
i have upgraded my rst brakes using 300mm discs and mk3 mondeo calipers. after replacing the m/cyl i have some pressure and the brakes work but still a fair bit of travel at the pedal. going to bleed some more. anyway i noticed the servo stroke can be adjusted (7mm dome nut) however there is only the one nut and the whole shaft turns. can someone explain wether this nut should undo or should the whole shaft turn to gain adjustment. id appreciate any feedback, cheers
Old 20-09-2012 | 05:24 PM
mgtkr1's Avatar
mgtkr1
anybody know what im talking about?
Old 20-09-2012 | 05:50 PM
haz87's Avatar
haz87
Yer use grips on the shaft (ooerr...) then undo. Small amount makes a big difference tho! Dont let it get to the point where the pressure cause the calipers to drag
Old 20-09-2012 | 06:51 PM
mgtkr1's Avatar
mgtkr1
cheers buddy. so lefty for firmness righty to gain pedal travel? just the lack of a locknut had me confused.
01-11-2015 07:53 PM
muzzman1
30-09-2015 09:59 PM
