YB Inlet support bracket - belleville washer help
I am in need of a few washers but can't source any local
So i'll try you kind folks if anyone can source or has any i will cover all costs etc
What i need is about 10x Belleville spring washers, also known as coned-disc spring, conical spring washer, disc spring
The sizes i need are M6 internal size & 14 - 18mm outside diameter and upto 1.5mm thickness
The same as this - tapered spring design
If anyone can help give a shout
Monte 087
Burton sell the mate, you only need 6 & the workshop manual shows you which way round to put them.
http://www.burtonpower.com/cosworth-...kit-sc565.html
I have used this company a lot at work and they deliver quickly. Not sure if worth mail order for small quantities but might work out cheaper than burtons. Pretty sure you will find one approx size
http://www.assocspring.co.uk/p/22/be...ers/?PAGE_ID=3
cossie fan (unluckerly)
Set of 6 belleville (cupped) washers to correctly mount throttle body on lower stud
It's a kit so it has 6 washers so you need to order 1 kit which is £4.84.
07-10-2015 12:56 PM
Johnny Knoxville
30-09-2015 07:21 AM
DavidK
27-09-2015 02:55 PM
