GT3040r (gt3082) on a cossie - opinions please
Has anyone ever used the gt3082 or gt3040r (same thing) on there cossie before?
If so what are they like? are they laggy at all or a good responsive unit?
Possibly looking at 1 for my 4x4 fiesta, would it suit my engine spec?
2ltr yb 8.2:1 comp ratio
10 long studs
lightened balanced polished & knife edged crank shaft
shot peened rods
cosworth racing pistons with valve cut outs
big wing sump etc
wrc breather
4x4 head, fully ported and polished
high torque cams (dont know spec as FMS own items)
2wd manifold with tial 44m external wastegate
hart inlet
seimens 83lb injectors
Would this be a good set up? it's a track only car so will be hard use and needs to be responsive and punchy out the corners, obviously the turbo choice will make or break it, going to speak with Tommy at fms tomorrow but missed them tonight by time id finished so wanted other peoples opinions who had maybe used 1 before?
Thanks
Marc
10 long studs
shot peened rods
big wing sump etc
wrc breather
hart inlet
Thanks
Marc
if its a 71 trim compressor and .82 exhaust housing it is imo the perfect turbo for you spec and needs..
If the cams are right then 480/480+ is possible
cheers danny
cheers danny
The 3040 is basicly 3082 hotside with a 35r cold so you get close to 3082 threshold with a little more flow from the bigger compressor. Some people have issues with the 35r(.82) being a bit of surge monster so putting smaller hotside on it might drive you further into surge.
If you can get the boost in safely it'll probably be knocking on 400(fly) on 1 bar ish and heading toward 480 on 1.5
