Pressure testing Cooling system
Old Aug 26, 2012 | 08:21 PM
Rob Virgo's Avatar
Rob Virgo
Default Pressure testing Cooling system
Any kits out there for finding leaks in cooling system ,losing water at a fair rate but can't find it , recon theirs a pin hole in rad as steam blows out when fans start. I want to confirm before stripping parts
Old Aug 26, 2012 | 08:28 PM
mechanic28's Avatar
mechanic28
i got a blue point one which is really good mind you it is expensive to buy just you use once lol just take of the fans easy on a sapp cossie then you will be able to see any damage
Old Aug 26, 2012 | 08:38 PM
Brendan's Avatar
Brendan
struggling with reality
Sykes Pickavant make a good one! pick them up on eBay too!
you can improvise by using a compressor set to about 3 bar and a modified screw top water cooling system! drill a hole to plum an adapter into the middle of the screw cap then pressure the system to about 45 50 psi using the gauge on the compressor then watch where the water comes out! DO not try pressuring to much as you can cause problems! I am sure somone else on here will be able to give you some more advice! If you are stuck to start PM me!
If in any doubt use some food colouring to make it a really strong colour! Remember to flush it all out!
good luck.
Old Aug 26, 2012 | 09:25 PM
stevieturbo's Avatar
stevieturbo
C**t
I certainly wouldnt be pumping 50psi into a system designed to run at 15-20psi.
You risk blowing hoses, heater matrix and the radiator.
I cant imagine an external leak being that hard to find, especially if as you say it is going at a fair rate.
Park it up let the engine run and watch for the leak. Of course, it could be internal too.
Old Aug 27, 2012 | 12:15 AM
Rob Virgo's Avatar
Rob Virgo
Was thinkin 50 psi might be a bit much...lol
Will check those brands online, cheers
Old Aug 27, 2012 | 06:27 PM
Brendan's Avatar
Brendan
You can use a tyre to drive the pressure too! this whay you can limit the pressure more easily!
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Fiddy
21
Sep 29, 2015 06:10 PM
SMILER258
Sep 28, 2015 09:04 AM
coscor86
Sep 20, 2015 01:21 PM
