Cat D Celica, shall I buy it?
Need a bit of help on this one!!
This guy is selling a Cat D celica 1.8 vvti 140. It has been repaired so all good. No history at all but he says the miles are genuine at 76k. He said it pulls to the left and that it needs a new shock.......I am thinking whatever happened to that car to make it a Cat D has not been repaired properly thus the pulling to the left?
Also.....anyone know what these Gen 7 Celicas are like as in MPG, speed, handling as they look pretty smart.
i wouldn't give any more than £800 for it and thats without seeing the car it would probably be less you can pick em up pretty cheap so a cat d and problems now worth the ball ache
as for the cars themselves there a mild sports coupe that can be out paced by most hot hatches, quite plastic but the handling is ok from what i remember its been a while
Engines aren't toyotas best either,seen quite a few in the scrappy with blown motors.
We repaired one before and the wheel had snapped off the front but it stood up well,no jigging as most of it bolts on and off,really easy to work on as well.
Their pretty lame in the performance department but as you sit low and they rev well they certainly give the impression of going fast,I didn't mind it.
The wheel went wonky on his after the repair and it turned out to be the hub,although I couldn't see why but a second hand one cured it right away,there's also a lot of adjustments on the suspension do it maybe just that.
I've never seen one under a grand so I think that's optimistic and check it is cat d not c as it really won't be worth anything if it is as generally the logbook is marked then.
Thank you for advise.
He wants £1,250. Its a 52 plate. 9 months MOT. Pictures are showing it looks clean.
So make sure it is a Cat D and not a C......Will call him a bit later today and find out.
How comes mate, are they really that bad? I have never even sat in one let alone drive one! The other car I have been offered is an Astra MK4 Coupe Turbo, but know nothing about these apart from they are meant to be the same performance wise as a Calibra Turbo??
No chance,you'll struggle to get the old twin headlight type for £600,rough,15 years old with 150000 miles on them,that's a grands worth of car all day long,it's only cat d which is nothing,you don't even need to tell the seller when you part with it and honestly who bothers to hpi a grands worth of car?not many,my text check.com at best.
Cheapest on autotrader is this one at £1550,so getting that at a grand or so would be a good buy.
The next cheapest is £1800.
http://autotrader.mobi/used-cars/adv...2jcp6a0h3ue676
that car you've linked to isnt cat D, it has a years ticket and 6 months tax.
The Ceilca the OP is thinking about buying has no tax, pulls to the left, needs a shocker and possibly more items if its pulling to the left.
people over value cat d cars all the times, including the seller of this one in questions, its isnt worth nowhere near £1250 IMO
More than just front bumper I was a Panel
Beater an jigged cars straight for years , if after
Repair it still pulls to one side ,after all a vic check is
Just check Id is rite not dig in to what's been repaired,
Pay few extra hundred quid an buy a straight car , as you
Could be chasing ur arse if the shocks bent the anti roll bar maybe
It pulls to one side and fella says it needs a shock
Bang on,I'm amazed how many people confuse a vic or VEHICLE IDENTITY CHECK with a full on inspection of the damage.
This being cat d it doesn't even need to go for that,it is recommended that you put it through a new mot but not law in anyway shape or form.
If its pulling it's almost certainly the suspension leg which is a really easy swap on these but should be accounted for in the price IMO.
I still can't see them as £600 cars but again each to their own and good luck if you can get them for that price,salvage seems more expensive than straight in some cases,particularly eBay and that Douglas valley breakers.
Wow can he overprice a car!!!
Thought i;d bump this to show what sort of money these go for (admittedly he mention about the clutch in the ad), this is a 2004, with 11 service stamps, not on the hit list & 1 previous keeper. I know what i;d prefer to buy!
http://www.ebay.co.uk/itm/180949805697?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649
So a rough example with a months mot,needs a clutch,no tax and a patchy at best description proves what exactly?
Have a zoom in on the front bumper,it's been hit and scratched all over,the bonnet doesn't line up properly either,pretty good chance that's been hit as well.clutch is a pig of a job,9 hrs in the book and I've done one in the flesh,not nice at all.
Looks like there's a dent by the drivers rear 1/4 as well and ask yourself this,if they haven't noticed any of those things I can see from a few crap eBay photos what else aren't they describing?the car still fetched £1250,clutch is £1-150 in parts at least £200 in labour,front bumper needs spraying,bonnet needs alignment so budget at least another £150-200 in the paint shop and the cars now at £17-1800 minimum.mot due soon so another £50-100 as cars always seem to need something and your up to pretty much £2000,or double what the other car was,sorry what it's worth.
Seen any for £600 yet?
I'd say it's unlikely you'll even get one pre-damaged for that, but perhaps we'll agree to disagree on this one.
07-10-2015 12:56 PM
muz
30-09-2015 08:29 AM
