are these MOT failures?
on the golf vr6 gave it a good going over today looking out for faults as i have the MOT soon.
slight pin prick hole in driveshaft CV joint, only put them on brand new a year ago! no leaking grease!
slight split (7mm) in the drivers side wishbone rubber bush, again they may not notice it and there is no play, these were genuine vw new a year ago
slight blow in exhaust joint
exhaust yes ,cv should if spotted ,but is up to the testers descrestion ,the bushes always go like that. ive had many mk3s that have gone thu no problems
If its an outter cv then yes if he spots it its a fail . And as long as theres no play and its not excesivley pershed and the blown from the exhaust isnt excesive then should be good . Oh and as above if hes not a total cunt .
I've always wondered this and as its relevant to this thread I'll ask.
If you have a hole in a cv boot from an object piercing it and the rest of the boot is fine can you patch it using a puncture repair kit?
I know it would look a bit odd but in theory it should work and will stop the loss of grease and the ingress of dirt and water.
Thoughts? Might be worth paceo doing this if the concensus is good.
Last Time, Get Off PF FFS
Yep. Inner cv boots failer has just come in according to a mechanic at Vosper Ford dealer. He glued a tiny hole on my O/S front cv inner boot. My Saph passed in the end even though one clamp on my exhaust was loose as fook
inner c.v boots are fail now damaged/deteriorated to the extent that does not prevent the ingress of dirt but from how you describe pass and advise, depending on extent of leaking exhaust pass and advise, i would say pass and advise on the arm bush
clean the rubber with degreaser and make it dry. then super glue, only a little bit mind... always works... and passes, as long as it doesnt crack open again before you test it.
Its gotta be said though, the surrounding rubber should flex around the join, my old xr2 had a super glued cv joint for 2yrs and it didnt let go.
Are some of you lot really discussing patching up cv boots with puncture repair kits or glue?
If it's got a hole in it, change it with a decent quality item.
What do you guys recommend for the blowing exhaust?.... Wattle and daub?
Should not have to bodge anything for a mot becuse if a car cannot be in first class condition one day of the year then it should not be on the road
Received 1,044 Likes
My mot tester is a good friend of mine.When i removed my reat axle at the begining of the year.When i bled the rear brakes i left the spanner on the bleed nipple by mistake and my mot friend didnt even notice it ha ha fpmsl.I could hear this rattle on the reat when i was driving the car.I found it to be the spanner ops ha ha.
I personally would believe this to be less of a bodge than just a bit of glue as it should be a more permanent repair and last far longer. Obviously if the boot is perished and cracked then it needs to be replaced.
