Any Focus Mk1 Suspension Guru's please??
Old 24-06-2012, 12:39 PM
svt-focus
svt-focus's Avatar
Default Any Focus Mk1 Suspension Guru's please??
Hi, i am not sure if this is the right forum , i looked through them all and it looks like this is the right place but please move/delete if necessary;
I have koni adjustable rebound front dampers with eibach pro springs just fitted to my st170, and i have standard rear shock absorbers with eibach pro springs.
As we all know the focus rear suspension has the springs seperate on the rear arms and the rear damper is a standalone unit in normal place;
The dilemna is i also have a new spax rsx coilover kit sat behind me but want to get my money worth out of the koni front dampers before fitting the whole coilover system.
Soo, is it ok to fit the spax rsx rear shock absorbers only for the meanwhile, meaning all the spax springs and adjustable spring stuff would not be used either.
Thanks in advance for any advice.
Old 24-06-2012, 07:35 PM
nevsrevs
nevsrevs's Avatar
depends how much/if shorter the new shocks our, but should be fine as long as it aint to long..
Old 25-06-2012, 12:27 AM
svt-focus
svt-focus's Avatar
are you referring to the koni front shocks or the spax rear shocks?
I think the rear shocks are the same size as the oem rear shocks, as the springs are what are adjustable as they sit on those adjustable seats for the height change on rear..
And as for the front koni shocks, they are shortened slightly to accommodate the eibach pro lowering springs better..
Does this help you at all?
Old 25-06-2012, 08:18 AM
nevsrevs
nevsrevs's Avatar
it should be fine then, as long as it is not for 1000,s miles
S3an
26-09-2015 11:39 PM
S3an
13
13-09-2015 10:01 AM
truffleshuffle
10-09-2015 09:35 PM
natehall
Ford Focus (All Models)
08-09-2015 05:13 AM
Quick Reply: Any Focus Mk1 Suspension Guru's please??
