Benefits of an OFAB ECU on a Mk1 Focus RS engine
Why would you run an OFAB ECU on a MK1 FRS?
What inputs does it need from the engine when wiring it up, where can I get information on this or wiring digrams?
Lol would be VERY surprised if someone had gone to the trouble of swapping over to that...the standard management is fully mappable as it is so can't think of any benefits of swapping to an older ecu, and as above can't see everything working in conjunction with it?!
I can't remember what the name of the management is on the focus but maybe it's a similar name and they are getting it confused with frst management?
Yes I am confused also, I spoke to the owner about it and it seems this is correct but need to do a bit more digging, I thought the standard Focus RS management was more than adequate. It's not in a focus now, but the engine and box are, so none of the anti theft stuff is there anymore.
Have just done a little research and the rs focus uses EEC-V management which is a updated verson of the EEC-IV that the fiesta rs uses. I can't see any benefit in using it over the standard management. At the end of the day why did ford create a new management if the old dated version is better. Simple answer is they wouldn't have
It is only a zetec turbo to be fair so i'm guessing the ofab must be much easier/simpler to wire up than the standard frs management which might explain things a little
There is a guy on here (JPA I think his username is) and he is a regular on West of Scotland RSOC site and he ran a Focus RS lump on OFAB I'm sure - it was a grey Mk3 Fiesta and was in PF about a year ago - could do a search and sure he could give you some pointers mate?
I think he broke the car so it might even be his old engine you are talking about? He upgraded to a mk3 Fiesta with Evo running gear!
Thanks, yes I know who you're talking about I saw his Fiesta at Knockhill.
I don't think the car or engine is anything to do with him unfortunately, it was converted by a tuner apparently, and has gone through a few people since, the workmanship on the electrics is terrifying so it can't be pinned on the original builder, but if it did come like that I'd be freaking out! The car itself looks well built, just needs some cosmetic bits seen to.
sure I read somewhere (could be wrong)that to get a focus rs engine running on standard management every sensor/connection has to be connected or engine will not run is this true
Can't be, thats all I'm saying....!
So now it looks like I need a Mk6 fiesta zetec wiring diagram, a Mk1 focus RS engine wiring diagram, and whatever ECU the thing is running diagram... The car needs another loom, don't know which loom has been used to wire it up but it's not a Focus one, it's either the standard Zetec loom or a fiesta rs turbo one.
so if the focus rs speedo instruments are dissconected it will still run?
not dissing you but thought I read this in a magazine
The engine doesn't know any different what is controlling it so all that antif theft malarkey doesn't apply.
It seems to run almost ok apart from an idle issue, which might be the usual FRS cracked breather pipe or the ISCV, but with the wiring looking suspect that needs to be sorted first.
It's not running the Focus RS management, the dash cluster is a fiesta 1.6 Zetec and only the speedo works I think, nothing else. I can easily fix it all once I've figured out what bits have been used to wire it up and anything that is missing just run a seperate loom. There are parts of the loom that aren't connected to anything in the bay, and at least two sensors on the engine that don't have anything plugged in, the fuel pressure regulator didn't have a vaccuum pipe attached either?
thought you was just asking lol what car are you working on?
what I ment was if you were to transplant a rs engine & loom & ecu staright out of a focus into a mk4 escort even with the key and transponder I dont think it will run
Lol possibly....I'm not sure if they were taken out though.
Yeah ok I know what you mean mate, there's probably some additional alarm gubbins that you need to swap over to to make it work, deffo won't be going on focus management so will have to figure out how best to fix it.
what gear box is it running? is there a triangle speed sensor plug coming off speedo drive? i have run a zetec turbo on ofab before and made a few looms if i can help?
