Cosworth 4x4 few issues/questions
Hi guys
I have a problem with my car it is a sapphire 4x4 cosworth and I think the release bearing is on its way out as I get a whining noise but it stops when I press the clutch pedal, I think the release bearing is on its way out. Is it a gearbox out job? Is it possible to do without a ramp or should I get it done at a garage? I had a price of £450 with a luk clutch.
Any advice greatly received.
Paul
Paul
It will be the box mate, your thrust bearing isn't been used when the peddle is released.
If it was making a noise when you press the clutch it would be release bearing.
Check you have correct oil in the box if that's ok then it sounds like main shaft bearing .
Anutternutter
21-08-2015 06:07 PM
charliecosworth
19-08-2015 02:00 PM
