Poor idle problem. Please help
Old May 17, 2012 | 12:52 PM
ermir's Avatar
ermir
FOCUS
Unhappy Poor idle problem. Please help
Im recently having problem with my focus mk1 i.6 idles. It dops under 400rpm when stoping or when puting in neutral. It happens when traveling in low speed or if you stop at the red light. Already cleaned the throttle and changed the spurt plugs (motorcraft titanium). The idle control seems to be ok. Does anyone have any idea.
Old May 17, 2012 | 01:12 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
You try plugging the idle control valve out?
Old May 17, 2012 | 01:23 PM
ermir's Avatar
ermir
FOCUS
Thanks NoRubNoDub, yes i tried unplug-in it it drop the idle to 0 i think. I checked it and i think it was cleaned? any idea? thanks
Old May 17, 2012 | 01:26 PM
alo's Avatar
alo
Sounds like the gearbox speedo sensor to me.try replacing that
Old May 17, 2012 | 01:28 PM
ermir's Avatar
ermir
FOCUS
Thanks alo, i havent heard it before. ill give a try. The dealer here in albania is not very professional.
Old May 17, 2012 | 01:37 PM
ermir's Avatar
ermir
FOCUS
Alo, but i have manual transmission, do i have gear box sensor?
Old May 17, 2012 | 03:08 PM
alo's Avatar
alo
Yes you have one. It stops the car cutting out when you dip the clutch. Its at the back of the gearbox with four wire multiplug on it.
Should solve the problem
Old May 17, 2012 | 07:39 PM
ermir's Avatar
ermir
FOCUS
Thank you so much, ill change it and let you know.
Old May 17, 2012 | 07:49 PM
ermir's Avatar
ermir
FOCUS
And also i think it might be this sensor because when i brake with the clutch pedal pressed it doesnt happens. It only happens when i brake and stop in neutral without pressing the clutch. The rpm goes over 1000 and then falls to 400 or somth. Thanks again
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
