heat shield
If turbo is on a 4wd manifold then housings will need rotating then it will be ok with standard downpipe, if using 2wd setup and manifold I am pretty sure the 2wd downpipe will be required as well, as the turbo sits in a different position, whichever setup you use just use the heat shield to suit.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
cossie09
10-09-2015 06:56 PM
