Crossflow question
Old Mar 9, 2012 | 09:54 PM
rossimarc's Avatar
rossimarc
Default Crossflow question
Bit unsure lads
Crossflow 711 block is it the same as XR2 mk1 block apart from the engine mount set up plus is there Many tuning bits for XR2 mk1 crossflow lump ?
Can u fit 711 block into mk1 fiesta
Many thanks
Old Mar 9, 2012 | 10:06 PM
Icurus's Avatar
Icurus
I think the fwd x/f was known as the Valencia?
Not sure if the x/f has the mounting points to allow it to be transversely mounted, never tried it myself.
Would be likely that the internals are the same though, rods, pistons, crank and cam.
Any info on the Burtons website?
Old Mar 9, 2012 | 10:16 PM
rossimarc's Avatar
rossimarc
bless you mate that all makes more sence
Old Mar 9, 2012 | 10:45 PM
GVK.'s Avatar
GVK.
Mk1 XR2 block is known as 771M , from US spec Fiesta. From what I remember, the Fiesta block doesn't have the engine mount holes for RWD application, and the old Escort 711M block doesn't have the holes for the Fiesta right hand engine mount. Not 100% sure on that though.
Found this Googling
I know the Haynes "Ford Fiesta 1976 - 1983 (#334)" covers the very similar crossflow block variant, the 771M (the Mk1 XR2's 1600 has no side engine mounts and a shortened water pump / timing chain/crank area which can't take a duplex timing chain), 'cos I've got one of them .
Valencia was the Fiesta engine 950,1100,1300 (modified Kent), then went to HCS in 1989 used in later Escorts and Fiestas, up to 1300cc.
Old Mar 9, 2012 | 10:56 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
yep my thaughts too
and HCS was then re-named as Endura-E in mk4 fiesta and mk6 escort/KA and Courier etc
cracking engines IMO when looked after
Old Mar 9, 2012 | 11:00 PM
GVK.'s Avatar
GVK.
HCS = worn camshaft anyone??
Old Mar 9, 2012 | 11:06 PM
Cossie Sean
i find this is because of numptys badly adjusting rockers, me included and i destroyed a brand new piper cam in 3 days that was in my 1660 711M mk2 escort, DOH
Old Mar 9, 2012 | 11:07 PM
Cossie Sean
another HCS one was non starting CFI`s, depress clutch and fires into life........... worn thrusts,
Never had any personal experience with worn cams on HCS but have heard of it
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
mondeomark
Sep 28, 2015 06:28 AM
